Plug Welding Tips Please
5 replies to this topic
#1 carlburt78
carlburt78
  • 239 posts
Posted 19 November 2013 - 08:53 PM
Hi guys after a disasterous first attempt at welding in my new A-post and stiffener im having to start again as my welding sucked and my plug welds didnt penetrate enough and were weak, so ive took the panels apart and i am going to start again,,, i have drilled bigger 8mm holes now but need some advice on plug welding techniques
i know this varies but what power setting approx on a 130 mig?
Do i start from the center of the drilled hole and work my way out?
or any other tips would be very helpfull thanks?
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,060 posts
  • Name: Neil
Posted 19 November 2013 - 09:00 PM
8 mm is large, i normally do them at 1/4". Power setting high with wire speed to match. I always try to start in the centre or slightly higher then puddle the metal until the hole is filled. You will need high power though to get decent penetration.
#3 Minidarren83
Minidarren83
  • 1,207 posts
Posted 19 November 2013 - 09:17 PM
How many power settings does your welder have? Mine has six and I use 3 for plug welds with a slightly faster wire speed than normal welding. I start in the centre and hold the weld there for a short time then work your way out
#4 carlburt78
carlburt78
  • 239 posts
Posted 19 November 2013 - 09:37 PM
mine has...........A 1  2  3  MIN OR MAX............... What is "A" setting on a welder?
#5 carlburt78
carlburt78
  • 239 posts
Posted 19 November 2013 - 09:44 PM
will i need any torch movement?
#6 sonikk4
sonikk4
  • 16,060 posts
  • Name: Neil
Posted 19 November 2013 - 10:09 PM
A small amount, if you start at the top of the hole then gently bring the torch back. Or if in the centre just a small amount of up and down. You will see when you try it on a hole. Don't hold the torch on for too long or you will burn through so have a bit more practise until you are happy.
With the power on high and the wire speed turned up it will fill the hole very quickly.
