I am new to the forum and new to minis and technical challanges. Was really hoping I could get pointed in the right direction, to what would seem a simple question.
I have recently purchased a 1293 engine, that was removed from a car and fully running. I have now received the engine and trying to work out a few things
The engine is fitted with a weber carb and z manifold, the inlet manifold has a port with a bango type plug attached loose, my feeling from what i can see it may have been linked back to the Brake sevo. However my car does not have a sevo.
The engine is fitted with only two breathers one from the rocker cover and one from the Clutch casing.
Looks like the Engine breathers have been open to atmospher with a hose and think that the inlet manifold was connected to the sevo on the car it was removed.
Looking for suggestions if i can plug the inlet manifold port, or do i need to use vacuum to my breathers to ensure no positive pressure in casings?
Also the car has an electronic dizzy, do I need to connect the vacuum hose as the weber has no vacuum connection port i can see.
Sorry for all the questions, really new to webers and set up and looking for any advice of support.
You help is appreciated to a newbie
Robin
