Main Beams
10 replies to this topic
#1 reallybig
reallybig
  • 613 posts
Posted 22 November 2013 - 01:10 PM
main beams on my right headlight don't work bul full and sides work
which wires in this pic are the main beams
#2 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 22 November 2013 - 01:13 PM
Main beam should be blue and white
#3 reallybig
reallybig
  • 613 posts
Posted 22 November 2013 - 01:26 PM
thanks
#4 Ethel
  • 26,077 posts
Posted 22 November 2013 - 01:46 PM
What are you calling main & full, to me they are the same thing?
Main, the blue dash light comes on - blue/white wire.
Dipped, other driver's don't flash you angrily - blue/red wire.
Probably the bulb or dodgy/connections / wiring at the light.
#5 reallybig
reallybig
  • 613 posts
Posted 22 November 2013 - 02:53 PM
main beam normal lights full beam max bright flashy lights
and changed the bulbs over to check that and after about 3 seconds the changed bulb worked so changed them back and it all works well now....
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 22 November 2013 - 05:29 PM
I'd be looking at the connections behind the grill to find the fault, and the main earth connection on the R/H inner wing on the bracing bracket, ones that fix themselves always come back
#7 reallybig
reallybig
  • 613 posts
Posted 23 November 2013 - 05:16 PM
Will give em a scrub tomo, any idea what the blue square things are on the wires
#8 Ethel
  • 26,077 posts
Posted 23 November 2013 - 05:22 PM
Scotch locks, they are intended to tap a new connection into an existing wire, and are used as a slightly botchy way to join cables.
http://www.minispare...ps/BAU2111.aspx - If you don't mind paying for a proper repair, also widely available via ebay etc.
#9 reallybig
reallybig
  • 613 posts
Posted 23 November 2013 - 06:37 PM
Shall i cut them out and wire in some bullet connectors or just leave them
#10 Ethel
  • 26,077 posts
Posted 23 November 2013 - 06:57 PM
I think I'd just splice the wire ends and cover in adhesive heat shrink, but replacing with a join free length back to the bullets behind the grille would be better.
#11 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 November 2013 - 07:18 PM
+1 on what Ethel said above, scotchlocks are the bain of a auto electricians world very short lived and poor connections always result sooner or later.
