Pre Paint Panel Wipe?
14 replies to this topic
#1 carlburt78
carlburt78
  • 239 posts
Posted 22 November 2013 - 04:33 PM
i need to give one of my panels a protective coat as its bare metal but i think its been sprayed with oil, what can i use to clean it off?
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,044 posts
Posted 22 November 2013 - 05:00 PM
An clean rag with paint thinners on it.
Edited by alex-95, 22 November 2013 - 05:09 PM.
#3 Tomm
Tomm
  • 2,462 posts
Posted 22 November 2013 - 05:07 PM
Effectively the above but don't use a rag contaminated with oil or the like as it won't be much good.
I personally use gun wash on clean tack rags, works as well as any panel wipe I have used, just seems to be a little cheaper.
#4 carlburt78
carlburt78
  • 239 posts
Posted 22 November 2013 - 05:11 PM
is white spirit paint thinners? hope so because ive got some in shed
#5 Daz1968
Daz1968
  • 2,058 posts
Posted 22 November 2013 - 05:15 PM
White spirit tends to not evaporate quick enough to remove everything, if it is bare metal I would use some cheap thinners on a clean rag and keep wiping till clean, then go over it again with panel wipe and tack rags before painting. Use an epoxy primer of you are leaving it a while before finishing.
#6 carlburt78
carlburt78
  • 239 posts
Posted 22 November 2013 - 05:21 PM
ive got etch primer, will that be ok?
#7 Daz1968
Daz1968
  • 2,058 posts
Posted 22 November 2013 - 05:27 PM
Etch primer really needs a top coat of some type to keep moisture out, you could just put a coat of aerosol paint on it then flat it off when painting car properly. But a coat of epoxy would be much better.
#8 carlburt78
carlburt78
  • 239 posts
Posted 22 November 2013 - 05:33 PM
you mean just spray the panel with an old aerosol only or etch aswell?
#9 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 22 November 2013 - 05:46 PM
White spirit is oil based keep it off your panels!
#10 Daz1968
Daz1968
  • 2,058 posts
Posted 22 November 2013 - 05:47 PM
Put it over the etch to protect panel.
#11 carlburt78
carlburt78
  • 239 posts
Posted 22 November 2013 - 07:41 PM
ok thanks will do
#12 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 22 November 2013 - 08:44 PM
Can you still get panel wipe? I still have a few litres, bit bought it years ago. Dirt cheap and made for cleaning down before spraying. Just make sure its a well ventilated area or you will float out afterwards.
#13 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 22 November 2013 - 09:10 PM
All paint suppliers stock panel wipe, pre clean, panel degreaser all the same stuff.
#14 carlburt78
carlburt78
  • 239 posts
Posted 22 November 2013 - 11:58 PM
i will make sure i close all the windows then LOL
#15 Daz1968
Daz1968
  • 2,058 posts
Posted 23 November 2013 - 12:09 AM
Panel wipe is low voc now so not to bad, you can even get water based panel wipe. You will have more fumes and smell with the painting.
