Reground crank sizes
4 replies to this topic
#1 kitch
kitch
  • 81 posts
Posted 23 May 2006 - 06:25 PM
Hi, does anyone konw what size the jounals should be on a 1275 non cooper s crank as I have recently bought a new engine and want to get new big end bearings.The guy who I bought it off said it had been reground to +20 thou but id like to check it before buying some
cheers
mark
#2 pikey7
pikey7
  • 3,824 posts
Posted 23 May 2006 - 06:34 PM
standard is 1.75" or 1.625" depending on which crank. No idea of tolerances though I'm afraid....
#3 kitch
kitch
  • 81 posts
Posted 23 May 2006 - 06:41 PM
cheers, mine are 44mm so they have been reground to +20 because thats 1.75"
anyone know what the main journals should be as mine are 50.3mm/1.98 inches, i'm hoping they should be 50.8"/50.8mm so that would be +20 aswell
also which bearings should i get AE or vandervell? is there much difference, i'm not tuning it much, just want a reliable runner?
cheers
#4 pikey7
pikey7
  • 3,824 posts
Posted 23 May 2006 - 06:48 PM
1.75" is 44.45mm. 1.73" is 43.942mm.
not sure on the mains size. it wasn't on the page I had! :thumbsup:
#5 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 23 May 2006 - 11:15 PM
Its not +0.020 inch (+20thou), that is Addative. It is -0.020 inch (-20thou), as grinding removes metal and is subtractive. Also either use metric OR imperial measurements, never both at the same time.
20 thousandth of an inch is aproximately 0.5mm
