Weber 45 Dcoe 9
3 replies to this topic
#1 gazza01
gazza01
  • 644 posts
Posted 25 November 2013 - 08:44 AM
Hi all.
I have recently purchased a weber 45 DCOE 9 from Ebay for a good price.
All being well once picked up, I shall be looking to set this up for my mini.
The mini is for fun weekends only, not a daily drive, and I am after a little more top end power.
The spec is 1330 with omega pistons, 276 cam, 1.5 roller tips, lightened flywheel, stage 4 head, recon box with hardened diff pin, centre main strap, centre oil pick up, and a full Maniflow 1 7/5 exhaust.
I am at the very start of doing some homework on these carbs so need some 'go to' info sites.
Firstly the no:9 type.  I have read the 13 was the one to have, something about flow down drillings, being better for Siamese ports.
So will this cause an issue or not.
I will need a jetting/set up chart to give me a good starting point for the above spec.
Who are the best guys to go to for R/R sessions when it comes to Webers. (I live in the south)
Also I only have the carb itself, so will be looking for inlet/linkages etc, preferably good used. Is there is a member on TMF
who is the weber 'guru' and has lots of parts, advice etc, who would that be?
Thanks in advance.
Edited by gazza01, 25 November 2013 - 08:46 AM.
#2 benpopham
benpopham
    The Carbon Weezel
  • 1,149 posts
Posted 25 November 2013 - 09:50 AM
I have a very similar spec engine to yours but with a slightly higher lift cam, larger bores and a comp ratio of around 11.5:1
My engine builder spec'd the 45DCOE 9 to go with my engine, less emissions friendly but better for performance where his comments, But other than that I dont know the difference.
So I would say, as long as you have it re jetted and set up for your engine you have the correct carb.
#3 benpopham
benpopham
    The Carbon Weezel
  • 1,149 posts
Posted 25 November 2013 - 09:52 AM
Also, for help setting it up, I would go to Brett Sims Motorsport in New Milton or Slark
#4 Ivor Badger
Ivor Badger
  • 846 posts
Posted 25 November 2013 - 11:56 AM
The 9 is for 1 port per cylinder and used by BMC on Healey 3000s. The 13 was for siamised ports on a MGB and then a mini. As pointed out, the only difference is the tickover drillings. Longman used to use both as sets on split Webers if that is how they came from the customer.
