Hello,
Long time user of this website but first time poster - phenomenal amount of technical information on this site which has saved me countless hours and hundreds of dollars so thank you to all. Time to now hopefully contribute.
I have been having problems with my 1999 Mpi for a few months - sometimes won't start, sometimes rough idle, misfire at partial or full load, etc. I have pretty much cleaned all earths and sensor plugs and the car runs mostly fine however the O2 sensor is reading way off the charts. I have an ACR4 and all sensors are working (including lambda sensor heating relay which I physically sighted working myself) however the O2 readings fluctuate from 0.02 to 4.6 V. I understand that it should fluctuate between 200 and 500 mV.
I recently replaced the sensor (believing it to be faulty) however it gives the same readings. I do not believe it is possible for a zirconia lambda sensor to produce more than 1.0 V so how is this reading possible? Do I have a short or is my ACR4 incorrectly calibrated?
Thank you in advance
