Engine Sounds Tappy Even Though Tappets Been Done.
bmt216a
, Nov 27 2013 10:40 PM
6 replies to this topic
Posted 27 November 2013 - 10:40 PM
Hello,
I adjusted my tappets to 12 thou but still sounds tappy.
Any ideas
Any ideas
Posted 27 November 2013 - 10:43 PM
Could be blowing exhaust
Unlikely but heck, its a Mini
Posted 27 November 2013 - 10:54 PM
Check the oil level, if it's low this might makes it more noisy than it should be. Or alternatively is the oil getting up there.
Posted 28 November 2013 - 07:05 PM
I thought they were always tappy, and the biggest reason for an alloy rocker cover was to muffle the noise a bit!
Posted 28 November 2013 - 07:27 PM
Could be wear on rocker pads, or even low quality oil
Posted 29 November 2013 - 11:48 AM
Usually associated with worn valve train, including cam follower bores, pitted followers and or poor rocker geometry.
Using modern high ramp rate cams also increases noise.
AC
AC
Posted 29 November 2013 - 07:33 PM
I've put a sw5 cam in it. I also de coked and lapped the valves. Will have a look
