1275/1380 Cooper S Block Aeg 312, St Aeg 480 Cooper S Crank , Aeg 177 Cooper S Rods
8 replies to this topic
#1 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 28 November 2013 - 04:16 PM
If interested please contact Darran   07866 606 286
 AEG 312  1275 cooper "s" block for sale its bored to 73.5 but has had minimal use. So is  very good,
have checked it over and is in excellent condition, has only one helicoil in the 11th stud, see pics. £450 ono
if asking price met will include a set of powermax pistons as well. Darran can put step liners in to take it back to STD if required.
 Also have AEG 480 special tuning crank from same engine at 10/20, this is the nitrided cross drilled one, crank nose is in exceptional condition, £400 ono.
Have two sets of AEG 177 rods as well £135 a set.
#2 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 28 November 2013 - 04:26 PM
any photos of the top of the block.
if its 73.51 that makes it a 1380cc
is this correct as a cooper s block can only be bored plus 0.60  72.16mm, i think
also is it thin flange looks like it
#3 Darranns149
Darranns149
  • 0 posts
Posted 28 November 2013 - 04:35 PM
Its 73.5mm and has not been offset, offset bored can go 74mm with out issue. Seen them at 74.7mm using triumph pistons.
I can put step liners in, to take it back to standard if required.
Edited by Darranns149, 28 November 2013 - 04:40 PM.
#4 Darranns149
Darranns149
  • 0 posts
Posted 28 November 2013 - 04:37 PM
Yes its a MK1 Block. Thin flange.
#5 Cooperman
  • 23,310 posts
Posted 28 November 2013 - 04:54 PM
Best thing would be to sleeve it back to 1275 cc. At that bore with no offset the head gasket would be vulnerable to blowing across 2 to 3 and it will not be sensible to try to ever bore it further.
At 1275 that block would be worth well over £650.
#6 Darranns149
Darranns149
  • 0 posts
Posted 28 November 2013 - 05:18 PM
Thanks for the advice, time is against me. Lots of projects on the go including getting maguire ready for next year. Thats the main reason for selling.
Head gasket is fully supported by block at 73.5mm bore, at 74 without offset id agree with you.
Edited by Darranns149, 28 November 2013 - 05:22 PM.
#7 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 28 November 2013 - 07:11 PM
maguire?????????????? were u racing that mini.
Special saloons
#8 Darranns149
Darranns149
  • 0 posts
Posted 28 November 2013 - 07:18 PM
Hillclimbs and sprints
#9 Darranns149
Darranns149
  • 0 posts
Posted 02 December 2013 - 10:20 PM
Bump
