guys i have a mayfair 1987 , and have fitted a servo of the internet, i cant bleed the front brakes ? if i pump the pedal i get air bubbles in the master cylinder ??? any ideas , i have a great fluid release from the rear bleed nipples , but the front is crap . thanks james
Servo
Posted 29 November 2013 - 05:10 PM
Posted 29 November 2013 - 05:16 PM
Which type of Servo?
also, moving this to the techie section - but welcome to the forum ![]()
Posted 29 November 2013 - 05:18 PM
what type of servo ? (^^^edit beaten to it)
is it one fixed to the brake pedal
or a remote type ?
you may have problems with the remote servo system on the later dual circuit ? as it is for single ?
(IIRC - memory not what it used to be)
Edited by sledgehammer, 29 November 2013 - 05:24 PM.
Posted 29 November 2013 - 05:25 PM
hi and thanks to u all, i have change the pedal box so its connected direct to the pedal, i was going to change the master cylinder seals ??
Posted 29 November 2013 - 05:37 PM
I bled mine from the master cyl direct , till I got a smooth flow of fluid , then I went to the calipers
it was a git to start - kept getting a soft pedal , when I tried bleeding from caliper first
hope this helps
Posted 29 November 2013 - 05:42 PM
ok cool , so the first connection on the master cylinder does the front or rear brakes ? i got a pressure bleeder today and i still have the air in the mater cylinder and thanks for your help mate
Posted 29 November 2013 - 05:51 PM
any ideas will be great i want my mini on the road ![]()
Posted 29 November 2013 - 07:03 PM
sorry I can't remember which is which - was over a year ago ![]()
Posted 29 November 2013 - 07:17 PM
It shouldn't matter which way round you connect it as they are both the same size. It can matter how you bleed it though as that will affect the operation of the limiter valve.
The convention seems to be to use the outlet nearest the servo can for the front brake line, which runs in a straight line through the limiter valve
