No End Float With Standard Thrust Washers On Laygear
Best Answer ACDodd , 29 November 2013 - 07:54 PM
Tolerance stack up is you issue. The cure, lap the thrust washer a few thou to give the required clearance. Ensure you keep the washer flat while you lap, check your progress using a micrometer.
Ac
Go to the full post
Posted 29 November 2013 - 06:20 PM
I've read that the standard thrust washers are the thinnest, yet with two different sets I'm unable to insert a 0.0015" feeler gauge, and gauging how tight the laygear is I would say there is no clearance at all.
Any ideals why I would have no clearance at all?
Posted 29 November 2013 - 07:54 PM Best Answer
Ac
Posted 29 November 2013 - 08:52 PM
Ac
Fantastic, diagnosis and solution, I'll get it done tomorrow. Thank-you very much
