Replacing Full Floor - Guidance Please
rust repair
12 replies to this topic
#1 CBJ805T
CBJ805T
  • 430 posts
Posted 01 December 2013 - 04:19 PM
Hi all, the slow restoration of my '84 Mayfair continues and I'm now at the stage to start thinking about replacing the floor. So much of the floor, sills and headboard are rotten that the most cost and time effective way of repairing it all is the change the whole floor.
I have the car on a spit and full bracing is attached. I'll have the door step / a post in place before proceeding to the floor
Has anyone tackled this job before and if so have you got any tips or pitfalls to avoid?
I was going to make sure the rear sub is in place before removing the old floor, and then use this as a datum for locating the new floor.
As I have the car on a spit, would you turn it upside down to allow gravity to support the weight of the floor when welding?
Do I need any additional bracing before removing the old floor?
Would you drill out the old welds from the inside or underneath the car? I.e. When fitting the new floor,Which panel should have holes in it for plug welding?
Thanks Chris
#2 Daz1968
Daz1968
  • 2,058 posts
Posted 01 December 2013 - 07:02 PM
I wouldn't fit rear subframe but I would make up a jig bolting to its mounting points as it will be a lot lighter
#3 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 01 December 2013 - 08:16 PM
steps and bottom of rear quarters on, flip it over and drop the floor in place. worst part of the job is drilling all the bloody spotwelds out!!  done a few full floors and they are quite easy.
#4 thetrev.com
thetrev.com
  • 84 posts
Posted 03 December 2013 - 07:30 AM
I will be watching this closely as I will be doing a full floor over christmas/new year after I have had the shell blasted.,
From other threds and project pages I have seen I think the bracing is ok and more than I have
I am in a similar position to you I was going to remove the bins and drill from the inside I was wondering if I needed to do the door steps before or after.
Have you got your floor yet or are you to order it? I was wondering if the stiffeners are fitter or if these need to be brought extra
are you taking photos of the project and creating a project page would be good to see progress.
Trev
#5 brum,brum,mike
brum,brum,mike
  • Just Joined
  • 554 posts
Posted 03 December 2013 - 08:12 AM
My shell is now braced up with a little more to do.
I do have the floor already, it has pretty much everything... jacking points, handbrake brackets etc.. If you specify which stiffeners your on about ill go and check for you ;D
We are leaving the rear subframe on its back mounts then lift the floor in and bolt them up to get us somewhere in the town, we are also doing the lower half of the bulkhead at the same time so i think we are also bolting the front subframe up with solid mounts .
Good luck, take lots of piccys!
#6 CBJ805T
CBJ805T
  • 430 posts
Posted 03 December 2013 - 12:40 PM
Hi All,
Thanks for your feedback. I'll have a look at making a jig for the rear sub.
Trev, if you're tackling this over xmas you'll be well ahead of me so I'd love to see some pictures. Do you know which project threads show a floor replacement? I had a quick search but couldn't find any.
I've fitted the door steps first so I have plenty to weld the new floor to and I was using the old inner sill edge to  help line up the new step - hope that makes sense.
As for the stiffener I'm not sure. Its not obvious from the images on somerfords etc.
Brum Brum Mike, the stiffener is question is the between the inner and outer sill which runs from the heal-board to the b pillar (ish). Where did you get your floor from? is the floor pan 1 panel or made up from 2 full length 1/2 floors and a tunnel panel?
Chris
#7 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,900 posts
  • Name: Neil
Posted 03 December 2013 - 12:56 PM
Hi All,
Chris
I made a jig using 3mm steel plate and 25 mm box section
3abfbba8-957a-439c-809c-65749dcb7933_zps
#8 brum,brum,mike
brum,brum,mike
  • Just Joined
  • 554 posts
Posted 03 December 2013 - 01:53 PM
Hi All,
Chris
I was lucky with a buy from ebay... brand new genuine full floor with just a little blue paint on. Its one big panel with inner and outer sill fitted with the heel board already welded on
#9 thetrev.com
thetrev.com
  • 84 posts
Posted 04 December 2013 - 01:06 PM
Hi Mike
the bit i am interested in is this
Closing plate against the bodyside in the base of the l/h rear companion/glove box now has a square pressing hole for later models
http://minispares.co...|Back to search
Trev
#10 carlburt78
carlburt78
  • 239 posts
Posted 04 December 2013 - 11:35 PM
how do you make a jig is it quite easy? Ive got heelboard work coming up too?
#11 carlburt78
carlburt78
  • 239 posts
Posted 04 December 2013 - 11:39 PM
Its ok ive just seen Soniks
#12 Minidarren83
Minidarren83
  • 1,207 posts
Posted 05 December 2013 - 12:34 AM
Hi Mike
Trev
Those little stiffeners fit at the rear if the inner sill inside the companion bin and are a very easy part to make to save some penny's
Hope these pics come in handy
Darren
#13 brum,brum,mike
brum,brum,mike
  • Just Joined
  • 554 posts
Posted 05 December 2013 - 07:45 PM
Hi Mike
Trev
No, they are not on the floor already, you will have to buy them separately or just make your own
Also tagged with one or more of these keywords: rust repair
