Evans Classic Waterless Coolant Installed- Now Have Luke Warm Heating
12 replies to this topic
#1 bmt216a
bmt216a
  • 58 posts
  • Local Club: Mini's of Tiverton
Posted 01 December 2013 - 10:49 PM
Hello,
Title says it all. New rebuild, was running just on water for a couple of weeks just to check for leaks etc and heating was good. Temp running about half way. Now installed the Evans waterless coolant, running the engine pretty hard around the lanes today, temp only reaching the 1st quarter, being a bit cold outside, put the heating on to only get Luke warm air.
Any suggestions?
Ian
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 01 December 2013 - 10:51 PM
Change the thermostat?
#3 OfMini&Men
OfMini&Men
  • 284 posts
Posted 01 December 2013 - 10:54 PM
What thermostat you running? good start point
#4 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 01 December 2013 - 11:05 PM
You might find that thrashing it around cools it more.
#5 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 02 December 2013 - 07:46 AM
How hot was it running prior to going waterless?
#6 finch661
finch661
  • 2,339 posts
Posted 02 December 2013 - 08:55 AM
air bubble perhaps?
#7 jaydee
jaydee
  • 8,565 posts
Posted 02 December 2013 - 09:01 AM
Try an 88° or, even better, a 91° stat.
An blank part of the grille opening if going below zero.
#8 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 02 December 2013 - 12:49 PM
Mine does this, remember the fresh air snorkle is attached to the heater, so outside air temp will have an impact on what is then warmed and sent into the car or windscreen. Try disconnecting or blocking off the fresh air intake on freezing cold days?
#9 bmt216a
bmt216a
  • 58 posts
Posted 02 December 2013 - 01:46 PM
It's a standard 998 thermostat, not sure what temp it's set at, it does work. No air locks as its circulating.
That cold air intake isn't connected at the moment as I lost the cowling that fits in the engine bay.
Why try a different stat then. I need to fit a weather shield too, that might slow down the cold air circulation.
#10 psychobob
psychobob
  • 205 posts
Posted 02 December 2013 - 03:38 PM
is there definitely no airlock in the heater matrix? as the heater takes its water from a bypass from the main circuit, it can still flow through the radiator fine, but still have air in the matrix.
#11 jaydee
jaydee
  • 8,565 posts
Posted 02 December 2013 - 03:46 PM
Its the basics of cooling systems..use an higher temp stat and your engine will warm up quicker and the heater will work.
If the stat opens at 74°, in cold weather, it will take forever to reach 85°-90° degs, if it will ever do.
#12 bmt216a
bmt216a
  • 58 posts
Posted 02 December 2013 - 04:15 PM
No air lock otherwise the Matrix would be stone cold. I'll get a new stat...
#13 Carlos W
Carlos W
  • 10,114 posts
Posted 02 December 2013 - 07:55 PM
See how hot the pipes going to and from the matrix are!
