Rear Subframe Captive Nuts
7 replies to this topic
#1 petey81
petey81
  • 1,334 posts
Posted 07 December 2013 - 07:47 PM
Hi
I am I the process of removing my rhs radius arm when I noticed the bottom bolt on the bracket that bolts into the heelboard area just fell out. Its the one on the subframe not the heelboad which I know you can get to through the sill and bins. Is this a new subframe? Cheers
#2 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 07 December 2013 - 07:56 PM
Potentially or just cut open and retrieve and weld a nut back in and weld up the frame.  Not easy and needs to be well done to keep strength.
#3 petey81
petey81
  • 1,334 posts
Posted 07 December 2013 - 09:17 PM
its the bolt in this pic
(not my picture by the way)
a friend told me it will be ok with 3 bolts holding the radius arm on!!! as its never moved!
#4 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,034 posts
Posted 07 December 2013 - 09:21 PM
I think there was a thread not long ago with the same problem, I think the best idea was to drill the hole bigger to be able to fit another nut in, then put a bolt on the nut to be able to hold it then weld the nut in.
#5 petey81
petey81
  • 1,334 posts
Posted 07 December 2013 - 09:32 PM
I think that pic is the thread but I found its the heelboard ones that cause issues which I've had to fix before. I will see what I can find.
#6 tiger99
tiger99
  • 8,584 posts
Posted 09 December 2013 - 09:05 AM
Whoever said that 3 bolts is sufficient is a dangerous incompetent, so you know where never to go for advice again. It would also be illegal and an MOT failure. And, if anyone comes along and suggests a Rivnut, don't listen to them either. A nut welded in properly is a perfectly safe and acceptable repair.
#7 petey81
petey81
  • 1,334 posts
Posted 09 December 2013 - 09:49 AM
Yeah I understand 3 bolts is not good that's why I didn't listen to him he was being stupid!! And I'm not stupid.
I know rivnuts and dynabolts are a bad idea.I'm removing both radius arms soon so will get a nut welded in. Cheers
#8 petey81
petey81
  • 1,334 posts
Posted 07 January 2014 - 07:30 PM
Now all sorted
Opened up the hole and jammed in nut then welded the gaps and smoothed over.
