How To Grind Welding Where Its Awkward?
19 replies to this topic
#1 ToM 2012
ToM 2012
  • 4,066 posts
Posted 08 December 2013 - 04:41 PM
hi i have welded accoss the inside of the top dash rail accross the bottom window lip. and i can not get the grinder in there to smooth it? it needs to be smooth as its painted after and can be seen. any ideas or tips on what to use? thanks tom
#2 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
B&D powerfile is brilliant for getting into awkward spots.
#3 sledgehammer
sledgehammer
  • 3,109 posts
Posted 08 December 2013 - 04:46 PM
if you have a good compressor , a die grinder is good if you have a steady hand
#4 ToM 2012
ToM 2012
  • 4,066 posts
Posted 08 December 2013 - 04:47 PM
any links lads?
#5 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,044 posts
Posted 08 December 2013 - 04:59 PM
this may be able to find it cheaper though
http://www.amazon.co...words=powerfile
#6 ToM 2012
ToM 2012
  • 4,066 posts
Posted 08 December 2013 - 05:08 PM
cheers alex ile have a look about i am going to need one. i am also after a spot welder any advise on where to get one from ? cheers tom
#7 mk1leg
mk1leg
  • 9,343 posts
Posted 08 December 2013 - 06:09 PM
Drammel tool with tungsten carbide bits...... :proud:
#8 g-dog
g-dog
  • 97 posts
  • Local Club: mini invaders
Posted 08 December 2013 - 06:59 PM
I use a set of grinding bits that fit in a drill Chuck. A round one,cone shaped one and a cylinder shaped one. Got them from b&q I think. Not the quickest method but it gets the welds tidy g
#9 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,090 posts
  • Name: Neil
Posted 08 December 2013 - 07:39 PM
A right angle high speed grinder with a oval carbide burr.
Burrs in r/h bottom of picture
#10 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 08 December 2013 - 07:45 PM
As above right angle or straight with tungsten burr. You'll be able to use it with wire brush etc, very handy little tool. Don't do as I did though, I bought a cheap one and it fell in bits. Buy a good brand, Sealey is the one I ended up getting, and its an ace liitle thingy!
#11 sonikk4
sonikk4
  • 16,090 posts
  • Name: Neil
Posted 08 December 2013 - 07:51 PM
Kobe right angle grinder will do the job and get the burrs from this company.
http://www.atimetals...es/default.aspx
They are not the cheapest but they are by far the best. I'm still using an oval burr that i used on Project Erm.
#12 Craig89
Craig89
  • 600 posts
Posted 08 December 2013 - 07:53 PM
+1 for the B&D powerfile. Don't know how I managed without it before I had it. In my experience die grinders and burrs can be abit too aggressive for bodywork
#13 sonikk4
sonikk4
  • 16,090 posts
  • Name: Neil
Posted 08 December 2013 - 07:56 PM
Each to their own but if you take your time then a burr will do the job nicely/ Its something i use at work on a constant basis. I used a power file once and it now sits in my toolbox virtually unused.
#14 ToM 2012
ToM 2012
  • 4,066 posts
Posted 08 December 2013 - 08:11 PM
sorry peeps whats a burr? still learning :shy:
#15 Minilegs
Minilegs
  • 242 posts
Posted 08 December 2013 - 08:23 PM
A rotary burr. Bottom rightish of sonikks picture. They are best ran at higher speed, such as air drill, ( I think :-) ) . They can be very agressive , but with a little bit of practise, they are very versatile and accurate. However, they can be mighty noisy:-) but hey Ho :-)
