Best Answer cambiker71 , 08 December 2013 - 09:20 PM
Further forward you'll find a joint where the rear section of the exhaust meets the front or cat, this will need to be loosened off so that you can twist the exhaust round (and at the same time upwards) then replace both exhaust mounting rubbers to hang it in the right place.
You'll need two of these....
http://www.ebay.co.u...=item4ac42ab111
Go to the full postPosted 08 December 2013 - 09:08 PM
Posted 08 December 2013 - 09:20 PM Best Answer
On the second photo there should be another rubber hanger between the car and the exhaust. That's all that holds it on though as standard
Posted 08 December 2013 - 09:42 PM
