Best Panel Company
Posted 10 December 2013 - 10:33 PM
Regards
Ben
Posted 10 December 2013 - 10:38 PM
Ben,
I'd recommend becoming a TMF+ member (£5 a year)
Then you will get discount with companies such as minispares (7.5%) as well as many others!
Get some pics up, and people will be able to advise you whether to go with repair panels or genuine full panels!
What is your experience/ability when it comes to repairs?
One of my big regrets was not fitting full heritage inner wings! I fitted flitch repair panels, then front half inner wing repair panels and a heritage panel would've been far better.
Fitting heritage panels tends to be easier, but they often need some tweaking!
Posted 10 December 2013 - 10:45 PM
ok fantastic will post some pictures up soon of the panels that are rotten and thank you for the advice will take that into account and join to TMF+ for £5 :)
With TMF+ membership and your budget is sound then buy Heritage. Minispeed will give you 12.5% discount on Heritage panels.
As mentioned Minispares will give you 7.5% on all of their items, panels, parts etc.
M Machine are very good as well for their own panels but you do need to check with them as some are Magnum panels which although usable are not the best.
Posted 10 December 2013 - 10:48 PM
To add to my last post your point of contact on here for Minispares is simon@minispares. Very helpful guy.
For Minispeed its scott@minispeed, again very helpful. Both members on TMF.
Posted 10 December 2013 - 10:51 PM
Posted 10 December 2013 - 11:37 PM
Heritage. I only use pattern panels if the Heritage equivalent isnt made anymore. Very few and far between though.
Posted 11 December 2013 - 04:43 PM
Plus 1 for M Machine panels
Only down side was they came in bare steel heritage come with a black e coat one less job to do
Posted 11 December 2013 - 06:54 PM
can you leave the black e coat on the genuine panels?
Posted 11 December 2013 - 07:14 PM
Only down side was they came in bare steel heritage come with a black e coat one less job to docan you leave the black e coat on the genuine panels?
Yes its totally differen to the ecoat you get on cheaper panels. It doesnt flake off and is a different finish. Satin rather than matt.
Posted 11 December 2013 - 07:29 PM
im glad i read this thread as ive got heritage sills and i was going to let the flapper disc loose on it
Posted 11 December 2013 - 07:31 PM
Posted 11 December 2013 - 08:22 PM
Do make sure you key the surface well before you paint them internally and externally.
will do
Posted 11 December 2013 - 09:28 PM
Heritage panels are miles ahead of any of the other makers.
M-Machine are the second best due to the high quality steel but they don't make all of the panels and often source heritage or magnum panels where they cant supply.
Im not a fan of magnum unfortunately, although I fitted a rear side panel and it didn't need much shaping in general.
If you want ease of fitting, heritage cant be beaten.
Posted 11 December 2013 - 09:39 PM
Forgot to mention this! By being satin it makes it easier keying it back to matt ready for paint
