Water Pump Replacement Question
10 replies to this topic
#1 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 11 December 2013 - 10:55 AM
I need to replace my wonky water pump pulley.  Trouble is I'm not sure how old my engine is - no engine number.  There are a few to choose from on the Minispares site,  How do I figure out which is the right one?
Cheers,
Tim
#2 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 11 December 2013 - 11:30 AM
I think the main difference is if you have a bypass hose fitted or not.
You can check that easily by looking to see if a small rubber hose links the water pump to the cylinder head - it's towards the back of the pump.
Once you know that then it's just a case of selecting the right one.
If it does have a bypass hose fitted make sure your renew it at the same time as the pump, and put the solid rubber one in not the easy fitment one.
Good luck with your scraped knuckles ...
Dom
#3 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 11 December 2013 - 11:40 AM
All pulleys will fit on all pumps, so you don't need to be confused about bypass hoses and impellors.
There are two basic sizes of pulley (excluding MPi as they are a poly-vee belt) and they are different enough that you can't really confuse them.
The following link has pictures and sizes - chuck a tape across yours and you should be in business.
If you don't fance shelling out for a new one, I do have a box of assorted pulleys sat in the shed.
#4 DomCr250
DomCr250
  • 667 posts
Posted 11 December 2013 - 11:52 AM
Missread the post and assumed it was a faulty pump, so your 100% correct on the pulleys.
#5 Mini Manannán
Mini Manannán
  • 2,860 posts
Posted 11 December 2013 - 01:14 PM
My bad, I didn't put 'pulley' in the title, not your fault!
#6 Mini Manannán
Mini Manannán
  • 2,860 posts
Posted 11 December 2013 - 01:28 PM
I gladly take a (straight :-) ) pulley off you!  :D
#7 Vipernoir
Vipernoir
  • 782 posts
Posted 11 December 2013 - 01:36 PM
Big or little ?
#8 Mini Manannán
Mini Manannán
  • 2,860 posts
Posted 11 December 2013 - 01:46 PM
I don't know!  I'd have to measure it.  by the way, I'm assuming the measure is the OD not to the bottom of the vee, is that right?
#9 Vipernoir
Vipernoir
  • 782 posts
Posted 11 December 2013 - 01:56 PM
They are different enough that it will be obvious.
#10 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 11 December 2013 - 07:27 PM
Just to add something. If your not sure about your engine I wouldn't go for a high capacity water pump, as the bigger ones can sometimes foul on the inside of the water jacket against the cylinder.
#11 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 12 December 2013 - 10:12 AM
I now only use my mini in fine weather so haven't had much experience of component life lately, but have had many A Series powered cars over the last 40 years and have always thought that the water pump was a weak point. They're under £20 so I'd replace that at the same time, and the bypass hose, and the bottom hose , as otherwise they fail at the most inconvenient time. - preventative maintenance!
