Spotlight Issue
2 replies to this topic
#1 lkopferschmitt
lkopferschmitt
  • 72 posts
Posted 11 December 2013 - 09:40 PM
I have a Rover mini Italian special edition and it's all running fine, except I noticed that the spotlights attached to the grill don't come on, either when in low beam or full beam.
They have cables running from then into the engine bay, but I lose track of them as they are close to the bottom of the engine which I can't really access unless its lifted
Any suggestions?
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 12 December 2013 - 08:52 AM
look around the bulkhead area for a relay. It's normal to wire spotlights through a relay so the problem could lie there.
I suspect it will have a blue/white wire going into one of the terminal and probably a brown
You could also be unlucky and find its something simple like both bulbs blown.
#3 jaydee
jaydee
  • 8,565 posts
Posted 12 December 2013 - 11:55 AM
Whoever did the wiring of these light at rover make them a nightmare to work with, and dealer fitted them even in worse ways.
The very best thing you can do, is take out all your existing wiring of these spots, bin all that crap, get a wiring kit, and wire tha stuff the proper way:
Hope this helps.
