Where Does This Ground Cable Go? (Rear Wiring Loom)
Best Answer lrostoke , 12 December 2013 - 09:07 PM
there should be a spade connection for it to plug onto on the light cluster
Go to the full post
6 replies to this topic
#1 colinu
colinu
  • 523 posts
  • Local Club: MOASF
Posted 12 December 2013 - 08:43 PM
The single black wire with a female spade on the end... where does it go? It near the rear left light cluster.
Year of vehicle... unfortunately a mix of everything from most eras, but my guess is this is a mid-80s rear loom.
Edited by colinu, 12 December 2013 - 08:46 PM.
#2 pmplovesminis2006
pmplovesminis2006
  • 143 posts
  • Local Club: north west mini club
Posted 12 December 2013 - 08:45 PM
im sure it pushes on to the rear light cluster
#3 ToM 2012
ToM 2012
  • 4,066 posts
Posted 12 December 2013 - 08:47 PM
same as above push it behind the rear light cluster bolt and tighten it acts as an earth.
Edited by ToM 2012, 12 December 2013 - 08:47 PM.
#4 colinu
colinu
  • 523 posts
  • Local Club: MOASF
Posted 12 December 2013 - 09:03 PM
OK sounds reasonable... although I would have expected the termination to be a ring or fork (not female spade) if it were to be clamped under a nut rather than pushed onto a ground tab.
#5 lrostoke
lrostoke
  • 6,923 posts
Posted 12 December 2013 - 09:07 PM   Best Answer
#6 colinu
colinu
  • 523 posts
  • Local Club: MOASF
Posted 12 December 2013 - 09:13 PM
OK, there my confusion... the original light clusters are long gone and this is a MK1 rear light conversion. I'll just stick a ring terminal on the wire's end and put it under under one of the cluster mounting bolts.
#7 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
yeah its a small spade connector... you can change the end for a ring terminal etc to use a bolt to earth it
