Hazard Switch To 4Pdt Toggle?
Posted 14 December 2013 - 04:51 PM
Also had trouble finiding the correct off/on/on switch for the headlights so planning to do this with 2 ordinary single pole toggles, one for side and then the other for dipped. I cant see a reason myself why this couldn't be done but would appreciate if someone could confirm or tell me it's a rubbish idea.
The reason for change is both aesthetic and i also think the toggle switch will be more reliable. I'm finding the original rocker switches to be a problem as the headlight one seems to jam sometimes and the hazard switch is a little temperamental. They've never felt the same after being opened up either.
Thanks for any advice.
Posted 14 December 2013 - 06:09 PM
There is a circuit kicking around for the hazard circuit using a DPDT toggle switch somewhere, maybe Kernow has it to hand. It's not a straight swap for the original switch and the circuit does need some modification in order for it to work.
I've use a push-button hazard switch in the past like this > http://www.polevolt..../info_8256.html to do away with the standard rocker switch, which also allows you to go to a single flasher unit instead of the two as standard.
This > http://www.polevolt....info_MTS54.html is the type of switch you need for dual side and headlights. It takes a little trial and error to work out the connections to allow both sets of contacts to work.
Phil.
Posted 14 December 2013 - 07:23 PM
Posted 14 December 2013 - 07:49 PM
Does anyone know...
Yes, and I've written it out here many times! You need to short together the common terminals of all 4 poles of the switch. Then one side of any 2 poles will become equivalent to the pair of terminals from the original switch that control the indicators. The other side of all 4 poles will become the block of 4 terminals at the other end, one for supply from the flasher, one for tell tale (you need to fit a tell tale remember) and one each for each side of the indicators.
The switch for the headlamps should really be an off/A/A+B type. They are not uncommon and if you can get one it will be a direct swap for the headlamps with no connections to puzzle over.
The original rockers are rated 16A so to be a direct swap you need to aim for this, ideally though the headlamp switch will be rated around 20 as 16 is marginal.
Edited by Dan, 14 December 2013 - 07:50 PM.
Posted 14 December 2013 - 08:19 PM
I have only managed to get a 10A switch for the headlights, but i have already added a relay for the side lights and a relay for the dipped, both fused and placed on the bulkhead so the switches are fine now.
Thanks again
Posted 14 December 2013 - 10:51 PM
Great, but remember to relay the main as well as dip beam. Sidelights don't need relays really. Make sure that you aren't building it in such a way that a single fuse or relay failure will take out all of your forward lighting.
