Mini B16A2 Bhp Guess?
4 replies to this topic
#1 MadMiniMan92
MadMiniMan92
  • 16 posts
  • Local Club: Southern Mini Club
Posted 15 December 2013 - 08:52 PM
Hi there i have a b16a2 engine with 1000cc gsxr throttle bodies and a dta management kit also the kit contains a 4-2-1 manifold what sort of bhp would i be putting out and has anyone else had this sort of setup would like to see a similar setup
#2 KMP
KMP
  • 18 posts
Posted 01 February 2014 - 06:47 PM
I have the b16a2 with CBR1000RR 42mm throttle bodies, Hondata inlet gasket, Dta engine management, 2.5" integra type-r manifold which goes to 2.25" centre section and 2 x 2" back boxes and mine made 190bhp!
Hope this helps.
Kris
#3 1293gt
1293gt
  • 324 posts
  • Local Club: nonw
Posted 14 February 2014 - 11:56 AM
180ish?
#4 MadMiniMan92
MadMiniMan92
  • 16 posts
Posted 24 March 2014 - 02:41 PM
Where did you find a trigger wheel for the dta or did you mount on one from trigger wheels .com to your standard crank pulley cheers for the replys sounds exactly the same as i am running hoping for the same result
#5 KMP
KMP
  • 18 posts
Posted 26 March 2014 - 09:32 PM
I bought the dta management from watsons rally, who make the conversion kit which I also purchased. The dta kit and loom comes with the toothed crank pulley wheel, well I believe I sent mine off for them to machine it. It also comes with the mount for the trigger sensor to be mounted in. They would be a good company for you to talk to about it, very helpful.
Kris
