My Mini Engine Does Not Shut Off, Even After Turning The Key?!
16 replies to this topic
#1 Stanley the Mini
Stanley the Mini
    Just On Tickover
  • 6 posts
Posted 16 December 2013 - 09:31 PM
Firstly, I am female...
Secondly, I've a massive issue with my mini, caused by me...
Any help would be greatly appreciated :)
After having a squealing mini for a couple if weeks, I had the belt checked and tightened, although it had already flattened the battery. I accidentally placed the jump leads the wrong way round on the points on my mini, whilst trying to charge the battery :(
Not sure what damage I've done but my stereo now doesn't work, there are two lights on the dash and although the battery is now charged (correctly) and the engine starts, I can only stop it by stalling him.
I guess I've frazzled something but can it be repaired??
I need to know where to start please...
Thanks in advance :)
#2 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 16 December 2013 - 09:33 PM
Check your fuses if they have blow replace them and everything should work again but dont take it from me 100% im no expert but check your fuses and if they have blown change them
#3 ToM 2012
ToM 2012
  • 4,066 posts
Posted 16 December 2013 - 09:34 PM
hi first to check would be all the fuses as you have probably blown them.
#4 Stanley the Mini
Stanley the Mini
    Just On Tickover
  • 6 posts
Posted 16 December 2013 - 09:48 PM
Ok, thank you :)
Job number one for tomorrow :)
#5 lrostoke
lrostoke
  • 6,923 posts
Posted 16 December 2013 - 10:28 PM
for the engine to still be running you still have power to the coil.
stalling the engine may stop it, but Im guessing power will still go to the coil. you could burn it out prematurely
something will be shorting on the ignition side...may have caused an arc in the switch, stopping it switching off power
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 16 December 2013 - 11:58 PM
You need to have the charging system checked with a voltmeter once you have sorted the issue of not shutting off, to ensure the alternator diode pack is not damaged and the regulator both could be fried, it should charge between 13.7-14.3 volts at 2000rpm plus.
Your radio may have a fuse inside to prevent incorrect polarity connections, if not its a service centre for the radio unless its cheap then it won't be cost effective.
Edited by KernowCooper, 17 December 2013 - 12:01 AM.
#7 grumpy dad
grumpy dad
  • 305 posts
Posted 17 December 2013 - 01:23 AM
what year is it
the two lights on the dash
and are thay on all the time ?
I think you will keep getting a flat battery
as the coil will be live all the time
so the only way to stop this is to disconnect
the battery each time you stop
until you get the problem sorted
Edited by grumpy dad, 17 December 2013 - 01:28 AM.
#8 Ethel
  • 26,073 posts
Posted 17 December 2013 - 01:38 AM
I don't see how been female makes a difference, blokes also do stupid  :shy: .
I guess by points you mean battery terminals? It shouldn't have done much, if any, damage if the battery was still connected, 12ish volts in opposite directions = not many volts in any direction. It can also only have got at anything that made a circuit i.e. was switched on or is always on. Again, very little is always on, but a modernish radio can have a permanent live for station memory, and anti-theft if it's coded.
Some more info would be useful on the switching off issue, year & model...
You could see if other ignition fed stuff works (indicators, wipers) after you've turned the key to stop it.
#9 Stanley the Mini
Stanley the Mini
    Just On Tickover
  • 6 posts
Posted 17 December 2013 - 07:12 AM
Thanks for all your comments.
I know very little mechanically about my Mini so simple terms is helpful :)
Yes, I mean battery terminals - I simply put the black lead on the positive and vice versa! (Didn't help that the garage had replaced the red rubber cap onto the wrong point!)
Stanley is a J Reg Mini City 1999.
The lights on the dash are the red and yellow/orange either side of speedometer and came on when I connected the battery correctly and got the car running. They stay in all the time.
When I took it for a test drive yesterday and arrived back on the drive I turned the key completely yet the engine remained running :(
The stereo is a modern one, so hope fully has just shorted itself out. I will check both the radio and fuse box today and let you all know the outcome.
Soooo much thanks!!!
#10 Stanley the Mini
Stanley the Mini
    Just On Tickover
  • 6 posts
Posted 17 December 2013 - 07:29 AM
Sorry, just to clarify after reading my post...
I've just started him up, first time, and he is ticking over nicely.
Indicators work but not the wipers. Headlights work.
Still running after turning the ignition off and that's when the two dash lights remain on, presumably because I have to stall him to be able to stop the engine?! Although these lights being on, hasn't flattened the battery overnight :)
Oh, and indicators still work too after switching off the engine!! Ignition fault??
I'm just feeling happy that at least he started up happily on this cold damp morning :)
#11 grumpy dad
grumpy dad
  • 305 posts
Posted 17 December 2013 - 09:28 AM
sounds to me like the ignition switch
to test
take the cover off that covers the switch
flow the wires from the switch
and you will find a plug unplug it
the lights should go out
if this happens put the plug back together
start car then unplug the plug
if the car stops its the switch
just buy a new one and fit
#12 Ethel
  • 26,073 posts
Posted 17 December 2013 - 10:13 AM
A few things still aren't clear, the rec light is properly called the charge light. It should come on when the battery and alternator are putting out different voltages. If it stays on, it could be because the alternator isn't working; you risk being stranded when the battery runs flat. Revving the engine can give a clue, if the alternator is working the light should get brighter. Dimmer suggests the alternator is faulty.
Grumpy dad could be correct look for the steering column connector with brown, white and a white/red stripe wire and you won't need to remove the cover to test. You still haven't told us anything that says if it's carbed or fuel injection, electronic ignition...
#13 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 17 December 2013 - 03:39 PM
Never ever remove the battery terminal while the engines running to make the car shut down, it will damage the alternator which will spike its voltage into the hundreds of volts.
#14 tiger99
tiger99
  • 8,584 posts
Posted 17 December 2013 - 04:05 PM
Yes, and it could kill you as well as the car!
#15 grumpy dad
grumpy dad
  • 305 posts
Posted 17 December 2013 - 05:52 PM
who suggested to remove the battery terminal with the car running  ?
