14" Wheels??????
Posted 25 May 2006 - 07:15 PM
Anyone know of any 14's that will fit and look cool?
[attachment=16218:attachment]
[attachment=16219:attachment]
Wheel i have at the moment.
[attachment=16220:attachment]
Posted 25 May 2006 - 07:20 PM
I considered some 14s before I found some CXRs. You won't find any with the right PCD off the shelf, but you have the option of making up some nice spacer/adapters to get them on. I hate to think of what something "skinny" like a 7" (lol) wil be doing to the bearing when spaced aswell though! I guess you might be into custom territory to get a reasonable balance of width and safety, in which case they can probably make them with the right offset and PCD. Not cheap though......
Posted 25 May 2006 - 07:30 PM
Can't afford specialist built 14" wheels just yet.
Posted 25 May 2006 - 07:34 PM
My mate is a tyre recycler so i can get some chunky boots 195 or even 205 wide, with 70 or 80mm off the rim and space the hell out of them... don't care if i need new bearings every few months... it only got to last the summer and will be back in for modification in the winter. i don't have to pay for tyres that dont fit, just take them back.
i bet u want them like hell tho lol
Posted 25 May 2006 - 07:37 PM
I'm not sure whats available for a 14x8, probably something RWD like BMWs or older Fords, and they *should* have enough offset for playing, and should be available in 14x7 also for the fronts.
Posted 25 May 2006 - 07:39 PM
I'm certain there are loads with the correct PCD (seen some A series metros with 14s), are you not thinking of offset?
I think turbo phill has 14" wheels on his mini?
Posted 25 May 2006 - 07:45 PM
Posted 25 May 2006 - 07:55 PM
Posted 25 May 2006 - 08:20 PM
turbo phils mini
Posted 25 May 2006 - 11:38 PM
Posted 26 May 2006 - 07:50 AM
Posted 26 May 2006 - 08:49 AM
look on HERE. A 101mm (or 4") PCD is only on a very limited number of cars, none (apart from the Mini really) are regular Kit car donors, and although the Ginetta is listed, most kit cars are based on Fords which use a 108mm PCD (or 5-stud wheel), VW Beetles (130mm PCD) or later Vauxhall (100mm PCD). And due to the relatively small demand, the aftermarket "market" is also quite limited (I'm not saying there are none out there, but while they are common in 13", the 14"s are quite rare). Even if there are wheels available in "kit car magazines", then I'm willing to bet that they are made by places like Image wheels, who will charge you £300 a corner for a custom fit Halibrand replica.
The only other "major" market for 4" PCD wheels is the caravan market. I doubt however that there is a great demand for any flash alloy over 5" width for them though.
Posted 26 May 2006 - 09:40 AM
Theres also the golf buggy market (you should see the golf buggy wheels you can get in America!!), but they are mostly 10s and wide...The only other "major" market for 4" PCD wheels is the caravan market. I doubt however that there is a great demand for any flash alloy over 5" width for them though.
Posted 26 May 2006 - 10:21 AM
Posted 26 May 2006 - 01:53 PM
the real ripspeed before halfords bought the name
