Windscreen - Fitting The Little Chrome Finisher?
10 replies to this topic
#1 Haynes
Haynes
  • 490 posts
Posted 17 December 2013 - 03:33 PM
Any tips on how to fit the little chrome metal joining piece that covers the join in the plastic fillet?
Just ordered up 2 new ones and was quicky reminded why they were left out previously.
#2 silve1999
silve1999
  • 1,146 posts
  • Local Club: MiniFreakz, Brighton Mini Club
Posted 17 December 2013 - 03:42 PM
slide in one end and lever the rubber in the other
#3 tiger99
tiger99
  • 8,584 posts
Posted 17 December 2013 - 04:33 PM
Lift one end of the filler strip, push the joiner fully on, and carefully lever the filler strip back into place. Slide the joiner till it covers the gap correctly, using a suitable tool such as a fairly blunt screwdriver to push it. Obviously lots of lubrication helps, try a non-silicone rubber lubricant, or soap.
#4 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 17 December 2013 - 05:13 PM
Get the little tool, it seems such a crappy bit of nothing you think why bother? Having done it both ways I can say it is more than worth the money. Use Hellerine oil (try a local electrical factor) to fit it and the job is pretty easy.
#5 Minilegs
Minilegs
  • 242 posts
Posted 17 December 2013 - 05:28 PM
Wear a nose plug if you use hellerine . It smells like old women and I really hate the smell!
But it is very good stuff!
#6 ToM 2012
ToM 2012
  • 4,066 posts
Posted 17 December 2013 - 05:30 PM
i must say my self the little tool is very good better then a screwdriver and etc. i used lots of fairy liquid in mine and me and my mate done it as its better with two of you. i did find after i done it fairy liquid was coming out from where it joins as we put loads around but it goes after time.
#7 midridge2
midridge2
  • 1,794 posts
Posted 17 December 2013 - 06:04 PM
Why are people talking about using the correct tool and lubricant? they are for fitting the filler strip not the little chrome finisher that goes over the two ends of the filler strip.
Just push in the bottom of the finisher then use a blunt screwdriver to push the top under the rubber seal.
#8 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 17 December 2013 - 06:40 PM
That would be because we haven't read the title properly ;-)
#9 ToM 2012
ToM 2012
  • 4,066 posts
Posted 17 December 2013 - 06:59 PM
i blame it on the other lot i read what they said  ;D
#10 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 17 December 2013 - 08:13 PM
i take full and complete responsibility for all of it ;D
Fixed it for you ;-)
#11 ToM 2012
ToM 2012
  • 4,066 posts
Posted 17 December 2013 - 08:54 PM
sorry i meant i take full responsibility for all of it not you tom ;D
