Stiff Gears Side To Side And Gets Stuck In Reverse
Posted 19 December 2013 - 09:41 AM
My Mini is a 1991 Mini City 1000
It first started when i went to pick up a friend from his house, i was sitting outside with the engine off and moved the gear stick side to side to check i was in neutral, when doing this i felt some resistence right in the centre before it slides over to where third and fourth would be, it almost clicks over in a way and recently its been getting worse and worse, so when im driving a long i go for third sometimes its just hars sliding it over and sometimes its like third and fourth and that slide over isnt there at all! It also gets stuck when reversing to the point where it feels as though there is no other gear but reverse after a lot of man power and fiddling you can eventually get it back to nuetral but i fear this problem is getting worse and would love some help from my fellow mini owners!
Thank you
Jake Webster
Posted 19 December 2013 - 09:46 AM
This can be something as simple as the selector oil seal right at the back of the box becoming wedged, or something as complicated as one of the selector forks inside the gearbox going out of place.
Have you noticed any oil leaking from the back of the engine recently?
Posted 19 December 2013 - 09:56 AM
Hey there, thank you for the fast reply!
There is always a bit of oil that leaks out in small drips around the sump area which might have something to do with it, do you think it could be linked to that?
Jake Webster
Posted 19 December 2013 - 10:56 AM
Would it be worth checking the gear change extension 'remote control housing' just under the gearstick first. Could it be just bone dry of grease?
Posted 19 December 2013 - 08:55 PM
Usual cause is the reverse idler bush walking out of the gear thus not allowing it to return fully home and holding the bell crank levers tight. Gearbox out job and rebuild to fix.
AC
Posted 21 December 2013 - 12:17 PM
Hello all, thank you for the replies! Touch wood its seemed to have freed itself after playing up for nearly a month but when next starts doing it i may just rebuilt it
Thank you all again, have a good Christmas
Jake Webster
Mini Technical Sections →
Problems, Questions and Technical →
Hif44 Starter Spindle Seal Fitment IssueStarted by JimmyStinkpickle , 21 May 2026 |
Help Pls! Engine Not Starting, Not Sure What To Do!Started by TheYoungestGary , 08 May 2026 |
Overbored Or Supercharged 850 Rebuild?Started by kkonstantinopoulos , 04 May 2026 |
Su Hs4 CarburettorStarted by Murrayup , 21 Apr 2026 |
Missing Speedo Drive Clamp PlateStarted by JimmyStinkpickle , 18 Apr 2026 |
