Hi All,
Nearing completion of my first engine build and need a little info on which thermostat housing and sandwich plate to fit.
Engine originally came out of a I990 Metro (1275) no bypass and I presume was fitted with the inline heater valve as the
head has not been drilled out.
The original items had two inlets on the thermostat housing and one on the sandwich plate (Both unusable due to corrosion)
would like to keep the same setup on the Mini when I get one, if this is possible? If not what are the options.
Many thanks in advance for any enlightenment.
Stuart
Edited by Stu1961, 21 December 2013 - 11:22 AM.
