Standard Mechanical Fuel Pump Psi
7 replies to this topic
#1 gazza01
gazza01
  • 644 posts
Posted 23 December 2013 - 09:49 PM
I would like to know if the standard mechanical fuel pumps can deliver enough fuel for the weber 45 DCOE. (3.5 max psi).
Thanks.
#2 Dusky
Dusky
  • 5,322 posts
Posted 23 December 2013 - 10:46 PM
I haven't seen many webers with a normal fuel pump . An electric fuel pump is worth the money too I heard ( some BHP gain).
However , the need of fuel depends on the car, so a normal fuel pump can be enough if the car doesn't need more fuel
grtz!
#3 Gremlin
Gremlin
  • 2,142 posts
Posted 23 December 2013 - 10:50 PM
The carburettor won't make any difference, what other engine modifications have you done as if set up correctly, any carb will need the same amount of fuel
#4 GreenMini17
GreenMini17
    Formally known as Chris-G
  • 424 posts
Posted 25 December 2013 - 08:51 AM
I doubt the standard pump would be able to supply enough pressure for the weber, especially up in the revs where the weber is very good. Its an easy and fairly cheap job to remove the old mechanical pump and fit a Facet (make sure its a real one, not a copy on ebay) either a fast road solid state or a red top. I think a red top would be over kill for just the one carb though. Give Merlin Motorsport a call and they will help you out. You may need a regulator too.
#5 coopdog
coopdog
  • 4,506 posts
Posted 25 December 2013 - 04:06 PM
I ran a 28/36 weber with the 25 year old pump with no problems.
But it's up to your if you want to run a newer one, won't do no harm
#6 Ivor Badger
Ivor Badger
  • 846 posts
Posted 25 December 2013 - 04:32 PM
Pressure has nothing to do with it, it's delivery volume that matters. The norm for a simple electric pump on a Weber was to use a MGC pump. Or possibly easier to find 2nd hand, the double pump from an XJ6. One side is enough to supply a Weber.
#7 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 25 December 2013 - 04:48 PM
don't want to steel the thread but am also going to be running a 45 dcoe weber on a 1380 with a Kent MD276 cam. would a electric pump be needed or will the mechanical one suffice?
cheers,
bear.
#8 GreenMini17
GreenMini17
  • 424 posts
Posted 25 December 2013 - 09:01 PM
cheers,
bear.
If your moving away from an su on a pretty much standard engine, i would use an electric pump. They are simple to install, pretty cheap and very reliable. I cannot stress how important it is NOT to buy a cheap copy version of a Facet pump. Facet pumps are the original and the most reliable. And get a bad name from the cheap copies floating around. They do a new pump called a Posi-Flo which is a much smaller plastic cased pump which could easily be hidden in the engine bay of a mini. Unless your a tight git i see no reason to keep the standard mechanical pump on even a slightly modified engine.
