Hi... I have a serious problem with my 998 mini..
Pressing the clutch down and engaging gear, when I lift clutch... no drive!!!
I thought it was the clutch master or slave so cleaned and re-sealed the slave.
Clutch seem to disengage okay.
but still no drive...
Jacked car up off front wheels.. engaged gear engine running...wheels do not rotate.
Looking down onto half shafts... one is rotating but not turning wheel....
In gear with engine running and clutch up...
there is a grumbling, rattly noise coming from somewhere in the engine but I cannot pinpoint it.
This may be a red herring but...
I took the clutch cover off and all looked okay.
I removed the central bolt and was going to take off the clutch assembly but did not have a adequate puller...so gave up. On inspecting the central bolt the tags had sheared off, but I refitted it as is.... I cannot believe that all the drive is through this bolt and there was no evidence of metal filings in the clutch cover, but is this a possible issue??
Help.... Has someone experienced an issue like this before.
regards
Stuart
