Mystery Plate, Does Anyone Know?
4 replies to this topic
#1 limby2000
limby2000
  • 366 posts
Posted 26 December 2013 - 09:50 AM
Hi everyone, I know this is of no use to anyone, but I have this question or enigma that bugging me. On stripping my mini 30 down to its tub and rolling it on its side , I discovered 2 x porely tacked plates located just in of the rear wheel turret on both sides. I initially suspected an historical most repair. However the subby would have had to be removed. I thought as I,m doing various repairs I would remove tacks and repair properly. On starting to grind off tacks it became obvious that it had various spot welds prior to the tacks. I evevtually cleaned up and ran a seam weld around to make me feel better about it. , not that it was visable above subby . My questions are what was the purpose of this plate, what was it hiding,,why was it porely tacked. I've seen a picture of a shell on the net with the same porely fitted plates . I,m sure there is other members that have wondered this. I understand that a lot of people will have views on this, but only bmc/rover will know the answer. All views are welcomed.Terry.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,053 posts
  • Name: Neil
Posted 26 December 2013 - 10:03 AM
It's a striker plate where there should have been a bit of felt between the subframe and boot floor.
This would have prevented any metal to metal contact between the subframe and floor creating noise etc. The felt made a lovely water trap as well so helping rust out in its continual quest to change our cars back to ferrous oxide.
Some folks leave the felt out and others use a thick piece of rubber to aid as a buffer between the floor and subbie. Other than that the plate serves no purpose at all.
#3 jpw1275
jpw1275
  • 2,803 posts
Hi.... From memory they are something to do with when the shells where manufactured they used these points for moving them around I think...or something like that....:0)
Cheers James
#4 jpw1275
jpw1275
  • 2,803 posts
Posted 26 December 2013 - 10:04 AM
Forget what I said...... I was wrong lol
#5 limby2000
limby2000
  • 366 posts
Posted 26 December 2013 - 06:41 PM
I must admit my first thought was of an assembly line jig hole.
