Mpi Engine Power Upgrades Questions
14 replies to this topic
#1 ukcooper
ukcooper
  • 1,625 posts
Posted 26 December 2013 - 04:02 PM
ok so ive done the easy bits, k&n, 52mm throttle body, 1.75" rear exhaust section.
I was not going the lcb way a I read there's not much to gain and moving the lambda censor screws things up?.
Now it's the not so easy bolt on bits.
Do I cam it with a Kent 274i or stage 3ish head or will the standard rover ecu handle both?.
I don't want to change the ecu or go 7 port etc.
Also is it worth putting a mpi on a rolling road for setting the engine up?
#2 Mpi Mark
Mpi Mark
  • 126 posts
Posted 28 December 2013 - 10:20 AM
Changing the head will see the most gains...I have looked at cams but they can cause issues I believe come MOT time.
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 28 December 2013 - 10:28 AM
I've had good results with the SW5i in MPi's and have put them through the MOT without issue... IMO you'll gain very little from the throttle body it's not like the MPi struggles for air through the standard one...
Upgrading to a larger valve head also works well, but don't go overboard on the porting, again it's not like it struggles for air flow
The main restricting factor of the MPi is the engine management system and the tall final drive.
I agree with the LCB, unless you move the Lamba to the main pipe, on the LCB it's only sampling from two cylinders
And unless you have a mappable ignition system then there's no point putting on a rolling road other than to see what power/torque it's delivering.. on a before / after basis
Edited by Guess-Works.com, 28 December 2013 - 10:29 AM.
#4 ukcooper
ukcooper
  • 1,625 posts
Posted 28 December 2013 - 01:02 PM
Ok good feed back rolling road info that's good to know.
Well the throttle body was free :)
Going go with a stage 3ish head. Gas flowed, reface and bit bigger valves.
Next question is it worth fitting the 1.5.1 rockers?. I now some people think there good and some people bad on a carb engine, but are they a improvement on a mpi?
Looking at other stuff it dose not seem worth fitting that facet power boost valve for this kind of spec?
#5 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 01 January 2014 - 03:07 PM
1.3 rockers would work better.
the fuel boost won't increase power as the name suggests, it a regulator so that the pressure can be adjusted, at high rpm on a highly tuned engine the injection system can start to struggle, so increasing the fuel pressure by restricting the return flow can help with this. I would wait until you have everything fitted and see if you need it
#6 ukcooper
ukcooper
  • 1,625 posts
Posted 30 January 2014 - 05:50 PM
So far I bought 1.5.1 roller tip rockers from med.
Edited by ukcooper, 30 January 2014 - 05:50 PM.
#7 ukcooper
ukcooper
  • 1,625 posts
Posted 30 January 2014 - 05:53 PM
Mini spares stage 3 mpi head
(35.7mm inlet and 29.3mm exhaust) and 180lb double valve springs Combustion chambers are set at an average 21.4cc
Edited by ukcooper, 30 January 2014 - 05:55 PM.
#8 sam-wkd
sam-wkd
  • 179 posts
Posted 31 January 2014 - 06:39 PM
I found that I needed the fuel pressure regulator after head work, cam and 1.5 roller rockers - it certainly smoothed things out and stopped it running lean.
Southam fitted my regulator and set things up for me and I had a before and after power run to see how things were.
#9 Mpi Mark
Mpi Mark
  • 126 posts
Posted 31 January 2014 - 08:50 PM
Hey UK cooper please let us know the difference the head and roller rockers make to the car,
is really noticeable ? I've got Lcb , K and n induction and an rc40 full stainless system. The cars suspension system is all sorted high lows negative camber etc and I'm now looking at taking the power up a bit. Thanks
#10 ukcooper
ukcooper
  • 1,625 posts
Posted 01 February 2014 - 12:49 PM
Don't hold your breath as not got a garage to work in but first good weather it be done. might see if I can a before and after power run.
#11 Midas Mk1
Midas Mk1
  • 5,784 posts
  • Local Club: S.U.N.M.C
Posted 03 March 2014 - 12:34 PM
Did you make any progress on this? :)
#12 sirjakethebrit
sirjakethebrit
  • 87 posts
Posted 04 March 2014 - 02:34 PM
Basically go the spec of a jcw90, the sw5 can runs fine, though I doubt as to actually making a difference. I've go a brand me fuel pressure regulator on fleabay if your after one of those.
I have a cooper works stg3 head, 1.5:1 roller rockers, mani + exhaust and de-cat, k&n 57i kit plus sc/cr gearbox with a 3.4very short final drive. It revs through and runs lovely and smooth but
It still feels slow. :-( but I have gone from a 270bhp 330lb/ft megane to this.
#13 ukcooper
ukcooper
  • 1,625 posts
Posted 04 March 2014 - 09:13 PM
No no and no progress so far :( working to much and still to cold for me outdoors.
Been looking at the sw5i cam as bought another engine so might upgrade that engine and swop the hole unit.
@ sirjakethebrit I have gone from a 270bhp 330lb/ft megane to this. Welcome to the mortal world :)
#14 sirjakethebrit
sirjakethebrit
  • 87 posts
Posted 04 March 2014 - 09:28 PM
Hahaha, to be honest I want using the megane as I was having more fun in the mini so I sold it. But I'm nodding it a bit more.... Well alot.
Id be more interested in seeing any difference in power proven by effects on a drag strip. I'm going to laugh at mine, sorry I mean run mine in minis vs bettles at York. If I can beat 18.5 I'll be flabbergasted!
#15 Minimuffmonster
Minimuffmonster
  • 13 posts
Posted 08 March 2014 - 07:04 AM
And the prize for most posts mentioning a "megane sport" goes to Sirjakethebrit! Haha they are hideous cars stick to a mini
