Buying A Battery
16 replies to this topic
#1 Remylebleu
Remylebleu
  • 709 posts
  • Local Club: On my ones :)
Posted 27 December 2013 - 12:13 PM
so my battery has eventually died and despite owning minis for quite a few years ive never needed to buy a battery before.
my mini is a standard 1980, 998, the only extra electrical device added to him is a radio, what battery would you recommend i get?
#2 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 27 December 2013 - 12:39 PM
I use an 096 battery, maybe overkill but why not when it's basically the same price?
You may need to file a little material off the bottom for it to fit completely.
#3 ukcooper
ukcooper
  • 1,625 posts
Posted 27 December 2013 - 01:19 PM
Me I go for the 075 Car Battery a little smaller than the 096 but I can get insulation around the battery for the cold winter months.
#4 HarrysMini
HarrysMini
  • 3,352 posts
Posted 27 December 2013 - 01:54 PM
Which you wouldn't need with 680 CCA :-)
Although, with a smaller battery, it's probably a good idea.
#5 lrostoke
lrostoke
  • 6,923 posts
Posted 27 December 2013 - 02:03 PM
another vote for the 075
#6 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 27 December 2013 - 02:16 PM
Have a look at Eurocar parts for battery offers - it means you can buy a much more expensive battery for less than somebody like Halfords.
As an example the 075 Bosch with 4 years warranty is less than £60 - always worth saving a few ££'s at this time of year.
#7 1275GTS
1275GTS
  • 668 posts
  • Local Club: bmc
Posted 28 December 2013 - 10:18 AM
Second for the 075 from Euro car parts. I got a bosch 075 earlier this year for £49 with 4 year warranty. They do special offer discounts all year round. A lot cheaper than Halfords.
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 29 December 2013 - 12:52 AM
075 all makes fit, but the larger 096 varies slightly in case size and some are a really difficult fit and rather than sit flat are wedged in the box to the point they are difficult to get out.
#9 firstforward
firstforward
  • 824 posts
Posted 29 December 2013 - 01:19 PM
I just fitted a Varta Silver top 096, had to slightly trim the battery length wise, no problems getting it out but maybe on some makes this could be an issue. Good price also...... http://www.tayna.co....tery-P3197.html
#10 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 29 December 2013 - 02:29 PM
Buy a Bosch/Yuasa silver one and you get a 5 year warranty! :)
#11 HarrysMini
HarrysMini
  • 3,352 posts
Posted 29 December 2013 - 02:47 PM
It's also worth noting if you are buying from Euro Car Parts, that you get 25% off if you are a TMF+ Member.
#12 firstforward
firstforward
  • 824 posts
Posted 30 December 2013 - 08:08 AM
5 Years with Varta Silver
#13 Remylebleu
Remylebleu
  • 709 posts
Posted 30 December 2013 - 01:01 PM
thanks for the advice guys, ive just checked euro parts and they have
lion 3year gtee £40 was £80
exide 3year gtee £55 was £76
bosch s4 4year gtee £60 was £62 (massive saving on that one)
exide premium 4year gtee £67 was £83
bosch s5 5year gtee £80 was £97
so is it as simple as the most expensive is best?
they are all 60ah and then range from 520cca to 600cca will i notice the difference in this? or is it not to relevant?
#14 egoist
egoist
  • 43 posts
Posted 17 August 2014 - 07:34 PM
So which would be better Bosch S4 or Bosch S5?
#15 HarrysMini
HarrysMini
  • 3,352 posts
Posted 17 August 2014 - 07:54 PM
S5
