Problem ??
Edited by sam138, 28 December 2013 - 09:45 AM.
Posted 28 December 2013 - 09:44 AM
Posted 28 December 2013 - 09:55 AM
Posted 28 December 2013 - 09:58 AM
Posted 28 December 2013 - 10:09 AM
Posted 28 December 2013 - 10:13 AM
I would get rid of the disposable bottles. In about 4 bottles time you will have spent the same amount as a proper regulator and a bottle of CO2.
When you swap to a bigger bottle, use ptfe tape between the threads on the bottle and the regulator. This will help ensure a proper seal. Also avoid lifting the bottles up by the tap on top of them. I've had a few bottles with faulty valves on the top and I reckon this is what is causing it.
Posted 28 December 2013 - 11:26 AM
Posted 28 December 2013 - 01:01 PM
I was always taught at college that you shouldn't use ptfe tape on them, the connectors are brass and soft so should form a good seal.
If the bottle leaks and you've bought a new regulator then either the reg needs to be returned as faulty or get the bottle changed as, surely, the gas company can't sell a leaky and basically dangerous bottle. Which is what my common sense tells me! :)
Edited by freshairmini, 28 December 2013 - 01:01 PM.
