Fitted My Wind Deflectors... Now The Windows Wont Close.. Help?
14 replies to this topic
#1 Chris1992
Chris1992
  • 2,022 posts
Posted 29 December 2013 - 01:33 PM
as in the title... fitted my wind deflectors after a lot of hassle (5 minute job my arse!!), even had to take the rubbers out to fit them... anyway, now the windows wont close all the way as the gap in the rubber is too small for the window to slide into.
has anyone fitted these to their cars? and if so, how did you get round this problem?
its a shame, they look damn snazzy
cheers guys
Chris
#2 Mini-Mad-Craig
Posted 29 December 2013 - 01:38 PM
If you bent them enough you shouldn't have to take the rubbers out, and the windows should still close fine. I used Climair ones on my Rover 114 which fitted really well, the windows were very slightly lower in their closed position but the Wind Deflector filled the gap.
How far does the window not close?
405516_2861569428133_1526616814_4700283_
#3 minimotion
minimotion
  • 196 posts
Posted 29 December 2013 - 01:43 PM
thinking about these for mine aint got a pic of them on have you?
#4 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,033 posts
Posted 29 December 2013 - 03:42 PM
I seem to remember someone saying (You might not have to) they had to cut a bit of rubber off, so that the deflectors fit in the bit you've cut out.
#5 GraemeC
GraemeC
  • 7,440 posts
Posted 29 December 2013 - 03:44 PM
Did you follow the instructions? If so there's your mistake!
They simply slot into the rubber where the glass goes, NOT between the rubber and the door frame as the instructions suggest.
#6 jb93
jb93
  • 2,439 posts
Posted 29 December 2013 - 03:55 PM
Yeah, from what I remember they were a bit of a pain when I fitted mine. They slotted in fine put when I closed the window it was too tight (not enough space for the deflector and the glass. I had to modify the rubbers ever so slightly to accomodate the window :thumbsup:
#7 Chris1992
Chris1992
  • 2,022 posts
Posted 29 December 2013 - 04:44 PM
ah right ok thanks guys. theres about half a cm gap at the top of each window, looks like ill have to mod the rubbers a bit
#8 PetePinnington
PetePinnington
    Formally known as PPinno
  • 367 posts
Posted 30 December 2013 - 02:38 PM
What ones are they? I fitted some climair ones to mine, went in within seconds and windows shut perfectly fine. Haven't got them fitted anymore though as I've got some Perspex windows with those silly little square openings XD
#9 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 30 December 2013 - 02:46 PM
+1 I heard some stories about them being a pain to fit but they went in in seconds. As said above they in the gap where the window normally sits NOT between the rubber and door. You shouldn't need to cut the rubber about at all.
#10 Chris1992
Chris1992
  • 2,022 posts
Posted 30 December 2013 - 03:46 PM
theyre the climair ones... must admit ive put them between the door and the rubber, ill try it the other way when ive got some time. thanks for the help guys
#11 l_jonez
l_jonez
  • 1,453 posts
Posted 30 December 2013 - 05:07 PM
My old sports pack had them fitted between the rubber and frame and I had no issues.
#12 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 30 December 2013 - 06:34 PM
mine are fitted between door and rubber, climair ones too.
my window stops short aswell.
when placed inside the window channel bit, they just fell out and moved around when you opened/closed the window.
#13 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 30 December 2013 - 08:36 PM
That is what the double sided tape on them is for. Were yours new or second hand?
#14 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 30 December 2013 - 09:00 PM
Second hand but came with replacement tape. Its a rubbish idea.
#15 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 30 December 2013 - 09:04 PM
The original stuff sticks like the proverbial to a blanket, that will be why yours flapped about. Never had a problem with mine, fitted in less than five minutes and don't move whatever you do.
