i fitted new ball joints to my car and the old ones were a @#~'er to split. they all went on nicely but now i need to take the hub off again to get my new engine in and i just cant split the top ball joint on either side. i managed to get the engine out by pulling the shaft (still in the hub) out as it went up but its soo hard as your fighting the cone. i cant try that again to get the engine in as it was just stupid. any ideas what to do???? also the joint bent the tuning fork open its that tight
Ball Joints......
Posted 29 December 2013 - 02:03 PM
Posted 29 December 2013 - 02:08 PM
Scissor type splitters are better.
Posted 29 December 2013 - 02:16 PM
the one with the bolt?
Posted 29 December 2013 - 02:17 PM
Yes. They don't chew the rubber boot like the scissor types do
Posted 29 December 2013 - 03:01 PM
iv lost my one of them lol will have to go hunting
Posted 29 December 2013 - 03:21 PM
Over the years I've had many different balljoint splitters, and encountered some very very tight ones which needed an extra effort to get undone.
The Pickle/Tuning fork type are utter rubbish - if they're strong enough to pop the joint they will destroy the boot, and generally they just splay outwards.
Cheap scissor types tend to snap or strip the thread when applied to a tight joint.
I'm currently using a very nice set of Sykes Pickavant splitters (which are adjustible for different applications) and they are the only ones that I haven't broken !
Posted 29 December 2013 - 03:43 PM
Posted 29 December 2013 - 04:09 PM
This is another vote for scissor type splitters. However, I don't use heat. I tighten them up until they feel ridiculously tight, then I take a brass hammer and strike the head of their tensioning bolt like it was a nail. The shock from the hammer blow in addition to the applied force easily unseats the tapered pin every time.
Posted 29 December 2013 - 04:12 PM
Posted 29 December 2013 - 04:37 PM
^ literally had to do just that yesterday, no heat just tightytight then bang bang bang with copper hammer...eventually popped off with a bang. Same as the clutch bolt!
Posted 29 December 2013 - 05:16 PM
yeah i thank you everone, iv never had too much of a problem before but might invest in a scissor one now :) so annoying becuse iv had them off a few weeks ago but didnt think id have to swap my engine
Posted 29 December 2013 - 06:26 PM
Do you mind buying new balljoint or not? Just had the same problem today.. SOmetimes you can unscrew the balljoin though.. So unscrew it where it meets the wheel, but you will need a good plier ![]()
Buying new balljoints today, I always seem to break them when getting them out... the thread is always damaged xd
Edited by Dusky, 29 December 2013 - 06:27 PM.
Posted 29 December 2013 - 06:29 PM
i did that the last time, need a bigger spanner tho, last time it was loose. they are new so dont really want to cut them but might have to in the end if the scissor thing doesnt do it
Posted 29 December 2013 - 07:05 PM
something like this works very good, don't know the name in english.. In belgium they call it a 'vise grip' ( google translate says ' locking pliers')
I had to cut mine too, changed theml in august, haven't drove the mini since then due to the paintjob etc ![]()
Posted 29 December 2013 - 10:20 PM
I believe the U.K. term for the tool shown above is/are "mole grips".
How/where would you use mole grips when removing ball joints? If you cut anything there will still be a tapered pin in the suspension arms and that still has to come out.
