Mini Starting/ignition Problems
5 replies to this topic
#1 mworsnip
mworsnip
    Starting My Mini Up
  • 3 posts
Posted 30 December 2013 - 08:06 PM
Hi all
New to the forums so sorry for coming straight in with a problem
I've had my 1971 Austin Mini off the road for a couple of years as I couldn't afford to run her.
Anyway I came to starting it again today and initially it went well
Got it running with the choke on, let it turn over for a bit but it died shortly afterwards
Thinking I mightn't have had enough fuel in it I went put some more in but after that couldn't get it to start for more than a couple of seconds at a time
It'd start and then shortly afterwards die
Could this be due to a blockage in the fuel line or the carb from all the crap that might have built up?
But then
Another problem, trying to get it to start again the ignition coil started making a large buzzing noise, which carried on after the ignition was turned off
to get it to stop we had to disconnect the battery, and reconnecting the battery brings back the loud buzzing noise at the coil
Any ideas much appreciated
#2 Dusky
Dusky
  • 5,322 posts
Posted 30 December 2013 - 08:12 PM
Welcome to the forums!
The first things that pop in my mind : Dirt in the carb, fuel pump that doesn't give enough fuel, carb float problem.
For the coil I think you have an electrical issue, check al the fuses, maybe you have a blown one orso?
grtz!
#3 mworsnip
mworsnip
    Starting My Mini Up
  • 3 posts
Posted 30 December 2013 - 08:15 PM
The dirty carbs were my first thought didn't get chance to clean them before this electrical mishap
Checked all the fuses and they're all intact.
I don't suppose replacing the coil would do anything would it, its the fact its still makes the noise with nothing from the ignition thats throwing me
#4 lrostoke
lrostoke
  • 6,923 posts
Posted 30 December 2013 - 08:36 PM
check for voltage at the coil positive, If disconnecting battery makes it stop suggests power is still getting to the coil with ignition off.
Carb probably wants a good clean , unleaded goes off and pretty sure it leaves a gummy residue after a while
#5 mworsnip
mworsnip
    Starting My Mini Up
  • 3 posts
Posted 30 December 2013 - 08:47 PM
Yeah its definitely still getting power without ignition, completely through me when it happened!
Upon re-inspection after disconnecting the coil and then reconnecting the battery there was still a loud noise which sounds like its actually coming from the distributor which surely can't be right because that gets its power from the coil right?
Well and truly thrown now, it may have to be put in the hands of somebody who knows a little more what they're doing
Edited by mworsnip, 30 December 2013 - 08:58 PM.
#6 Ethel
  • 26,580 posts
Posted 30 December 2013 - 09:21 PM
Possibly the horn buzzing, any relays? Fuel faults can be tracked down by splashing a little fuel into the carb throat. Float chamber vent blockage is another possibility to investigate for the cutting out.
