My Mpi Gearbox Rebuild After Diff Pin Failed
3 replies to this topic
#1 Jake Didsbury
Jake Didsbury
  • 294 posts
  • Local Club: Barnsley Mini Club
Posted 02 January 2014 - 11:41 AM
Hi all,
Around sort of July time last year was on my way to pick my girlfriend up to take her to the cinema car seemed to be ok, pulled up at her house got out went to get her, got back to the car fired the car up, just pulling out of the car park near her house noticed the steering seemed to be feeling funny, it had felt ok on the way there but a few days previous id noticed few odd things, but all of a sudden on after leaving it went really stiff, but not stiff through out the lock only in places, got down the road an I said were gonna have to go back its not safe to go out in this plus we needed to go down the motorway, so we went back and go her mini.
Left mine over night, decided to go to work in it the next day which is just down the road was thinking maybe a steering component was knackered or even if the rack was damaged excessive play somewhere etc.
Anyway took the car off the road and spent ages trying stuff an I couldn't fully explain to people what it exactly was doing, until one day someone said, 'have you thought it could be the diff?' maybe im silly for not thinking it but the Diff never even entered my mind but it can effect steering, now when this person had said this id actually took the car out to go see them at there house cause we'd all just been to a local car show and I nipped back home to fetch my car to show them, when I got there oil was pouring out the gearbox not pouring but alot of it dripping out, jacked the car up ran it in gear an there was a terrible noise coming from the diff so thats what it was, so got the car over the pit at my grandads garage one Saturday and started to take the engine out, was abit nervous as Ive not done this before and MPI engine bay has alot of stuff in it haha.
Luckily I had built a gearbox before so id hoped the damage wouldn't be too bad
Attached File  IMG-20130823-02109.jpg   73.68K   4 downloads
Attached File  IMG-20130824-02111.jpg   87.08K   4 downloads
Attached File  IMG-20130824-02112.jpg   77.04K   3 downloads
Attached File  IMG-20130824-02113.jpg   77.83K   3 downloads
Attached File  IMG-20130825-02115.jpg   91.29K   0 downloads
Had a look when I got it back to my workshop this showed something had certainly gone wrong in there
Attached File  IMG-20130825-02116.jpg   47.25K   13 downloads
Scoring around the Diff cage and cracked cover, found bits of planet gear in the bottom
Attached File  IMG-20130826-02120.jpg   50.25K   9 downloads
Damage to the machined face where to cover fits up
Attached File  IMG-20130826-02123.jpg   60.79K   10 downloads
Started the strip down, hoping there wasn't too much damage
Attached File  IMG-20130827-02137.jpg   71.13K   3 downloads
Attached File  IMG-20130828-02138.jpg   43.78K   1 downloads
Sat the engine onto an old remote box I got for the time being so I could sort the gearbox
Attached File  IMG-20130828-02140.jpg   84.15K   0 downloads
Got the box on the workbench ready to strip
Attached File  IMG-20130828-02141.jpg   79.08K   4 downloads
Bit of planet gear that was stuck to the sump plug magnet, (did its job well)
Attached File  IMG-20130828-02142.jpg   72.24K   14 downloads
Also found this in the bottom of the gearbox when I first took the diff off
Attached File  IMG-20130826-02118.jpg   50.87K   4 downloads
Box stripped
Attached File  IMG-20130828-02144.jpg   78.3K   6 downloads
Like to start off with a clean bench and bins labelled up so nothing gets lost, had to keep it that way though haha
Attached File  IMG-20130828-02145.jpg   73.06K   2 downloads
So I inspected the casing, and the damage was, a dent into when the diff cover fits up the gasket face as shown in the picture, and what the most worrying for me was a crack where the planet gear had been fired into the central webbing that holds the 3rd motion bearing.
I'm pretty stubborn and I wanted to save the gearbox and keep most of it original to the engine so I vee'd out the crack and took it to a place the had an aluminium welder, it was aluminium MIG.
The weld ended up being abit lumpy and built up quite alot but it did fill in the crack id vee'd out
the guy did it for free too
Attached File  IMG-20130831-02152.jpg   40.71K   7 downloads
Because the weld had built up alot I couldn't completely see if all the crack was filled in om either side of the webbing and it looked abit messy so I took it back and sat out side at a table nd spent an hour or so with the dremal grinding it back to shape to see that it had done its job.
It was tricky getting in the with the dremal so I couldn't get it completely smooth but it was roughly the right shape, I never got any photo's of the weld before
Attached File  IMG-20130831-02154.jpg   75.03K   17 downloads
Attached File  IMG-20130831-02157.jpg   82.49K   9 downloads
Took it to work the next day and got the die-pen spray on it, didn't show anything up so was pleased
Attached File  IMG-20130831-02158.jpg   73.82K   11 downloads
Part of my job involves Beed Blasting so it comes in handy now and again with parts I once did a casing in there for a friend who's gearbox I rebuilt, so decided to do my own.
I'm quite pedantic with some things so I made a set of nylon bungs that fit into the bearing housings to stop the glass beed wearing the machined faces away during blasting as they are part of the precision and form the interference fit of the bearings also.
This isnt the same gearbox, I only have pictures of the one from my car after it was done
Attached File  beeed.jpg   43.65K   6 downloads
Attached File  420775_457309251018127_1627131233_n.jpg   43.22K   5 downloads
Attached File  551432_457309194351466_2086253886_n.jpg   35.66K   4 downloads
Attached File  562387_457309161018136_2028009278_n.jpg   39.46K   5 downloads
This is the one from my car the only picture I got after it came out the cabinet
Attached File  IMG-20130902-02165.jpg   62.67K   7 downloads
Degreased/oiled all the parts and set off putting it back together with new parts where needed such as the usual musts like main bearings and baulk rings etc I reused the needle bearings that the gears spin on, put new layshaft bearings in though and idler bearing
Attached File  IMG-20130903-02169.jpg   84.78K   8 downloads
Main shaft back together
Attached File  IMG-20130905-02178.jpg   73.72K   4 downloads
Attached File  IMG-20130911-02186.jpg   58.86K   5 downloads
Attached File  IMG-20130911-02188.jpg   59.71K   2 downloads
Attached File  IMG-20130911-02190.jpg   69.64K   6 downloads
Attached File  IMG-20130912-02200.jpg   73.47K   2 downloads
Attached File  IMG-20130912-02201.jpg   78.03K   1 downloads
Once the main gearbox was built I started to clean up the other parts
Attached File  IMG-20130912-02192.jpg   55.88K   1 downloads
Attached File  IMG-20130912-02193.jpg   51.42K   0 downloads
I decided to clear Lacquer all the aluminium stuff to try to at least keep it looking like it did when it was blasted so I masked of the bits I didnt want to get any overspray into
Attached File  IMG-20130912-02196.jpg   69.53K   2 downloads
Attached File  IMG-20130912-02197.jpg   77.37K   3 downloads
Attached File  IMG-20130913-02202.jpg   61.75K   0 downloads
Attached File  IMG-20130917-02207.jpg   52.69K   1 downloads
Chose not to do this until id built it gave it a few coats of clear lacquer
Attached File  IMG-20130919-02211.jpg   77.53K   3 downloads
Edited by Jake Didsbury, 04 January 2014 - 12:46 PM.
#2 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 02 January 2014 - 04:05 PM
Impressive work! My SPI did a similar thing, so I ended up getting a new gearbox from Guess-works.
I just bought a disassembled MPI gearbox with a good case and I am going to see if I can assemble one spare out of the two. But you gave me some hope that the damaged case can be repaired too.
Cheers,
Ivan
#3 Jake Didsbury
Jake Didsbury
  • 294 posts
Posted 04 January 2014 - 12:23 PM
Cheers,
Ivan
Thanks Ivan :) that sounds like a good plan, by the looks of yours it hit in almost the same place as mine, I think when its like that the case can still be saved just depends I suppose its quite a stress critical area but thats not too bad I dont think, just that chunk its took out could have that welded up though I think, but if you have a spare case now thats good
#4 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,147 posts
  • Name: Sean
Posted 04 January 2014 - 01:41 PM
Nice work, I did find it amusing that you were more concerned about taking the mpi lump out than doing some serious engineering on the gearbox!!
