Rear Wheel Cylinder
Posted 04 January 2014 - 06:08 PM
Daniel
Posted 04 January 2014 - 07:18 PM
They improved the feel as the pedal it right there. I have read a few times on forums that you get a slightly longer pedal with four pots, I wouldn't know because I have never run them or driven a mini with 4pots fitted.
Posted 04 January 2014 - 11:25 PM
I dont know what M/C i have but at the moment the brakes are standard for a '93 with a servo, i might just order the cylinders and if i dont like it then change for some a larger size, there are plenty to choose from and there cheap enough, i havent put the 4 pots on yet so dont know what difference they will make to pedal feel or travel!.
Daniel
Posted 05 January 2014 - 01:20 AM
Hi
hope this helps
the bigger the wheel cylinder
the more pedal travel you will have
and the harder you will have to push
don't forget you want about 80% of the braking at the front
Posted 05 January 2014 - 01:40 AM
The harder you will have to push?Hi
hope this helps
Posted 05 January 2014 - 09:12 AM
Hi
hope this helps
Posted 05 January 2014 - 09:37 AM
i only know simple hydraulics. pressure is equal to force x area... with 4 pots (assuming they make a collective lager piston surface area than 2 pots) surly should decrease the amount of force needed to apply the same amount of px ??
however due to the increased volume of fluid required the pedal travel would be further (more fluid displaced)
Posted 05 January 2014 - 09:46 AM
The harder you will have to push? the brake pedal
Posted 05 January 2014 - 12:12 PM
Hi
hope this helps
Bigger wheel cylinders = more travel on the master cylinder but LESS force needed!
Posted 05 January 2014 - 04:29 PM
So by fitting the smaller 1/2" cylinders it should offset the longer travel produced by the 4 pots?! I think the reason I read about was to fit the smaller cylinders to stop the rear wheels locking up before the front wheels and therefore giving better and more stable braking, does anyone have experiance of this?
Daniel
Posted 05 January 2014 - 05:48 PM
Hi
hope this helps
That's to get the same braking force on the REAR wheels! In practice 80% of braking is on the front so you just push the same and get slightly less braking on the rear!
Posted 05 January 2014 - 07:48 PM
Exactlyi only know simple hydraulics. pressure is equal to force x area... with 4 pots (assuming they make a collective lager piston surface area than 2 pots) surly should decrease the amount of force needed to apply the same amount of px ??
Posted 06 January 2014 - 07:33 PM
have you got the dimensions for the 4 x front pistons and the 2 x rear pistons ?? and the slave and masters
i can do maths ;)
