Is This Valve Spring Compressor Suitable For An A Series?
10 replies to this topic
#1 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 04 January 2014 - 06:43 PM
Just a quickie, is this valve spring compressor suitable for a Mini engine?
http://www.machinema...ring compressor
It looks similar to the Minispares one, but they want £8 to post it, while I can collect from Machine Mart.
Edited by HarrysMini, 04 January 2014 - 06:44 PM.
#2 DannyTip
DannyTip
  • 1,020 posts
  • Local Club: A Series Magpies
Posted 04 January 2014 - 06:56 PM
It looks very similar to the one i used to do mine. But it wait for someone to confirm.
#3 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 04 January 2014 - 06:58 PM
It'll work. But so will the one above. The one you linked is a good general purpose one and has more clearance for ohc heads. I've got one of each. The one you linked also doesn't have as much room around the collets but will work fine and will also work better for other cars you may end up tinkering with.
#4 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 04 January 2014 - 07:01 PM
Mine is more like this actually...
#5 HarrysMini
HarrysMini
  • 3,352 posts
Posted 04 January 2014 - 07:13 PM
Okay, thanks. I think I might get the cheaper one as I'm not going to be doing major engine work on anything but an A series.
#6 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 04 January 2014 - 07:57 PM
I have one of those and find it a pain with a series heads. I have to use a stack of big washers to pack it out and get it to work. I got one of these and it works much better:
http://www.amazon.co...ring compressor
#7 Ryang556
Ryang556
  • 2,747 posts
  • Local Club: Top Mini
Posted 04 January 2014 - 08:10 PM
I always find the ones like that are a lot easier to use on any head  :lol:
#8 HarrysMini
HarrysMini
  • 3,352 posts
Posted 05 January 2014 - 07:22 PM
Are these of good quality then? It just seems a bit cheap to me, and it looks like it's made of plastic?
I might get that one if it is though, and it is definitely suitable for an A Series?
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 05 January 2014 - 07:35 PM
I use one of these... http://www.machinema...ring compressor
and as mentioned above I have a fairly thick washer welded to the end of the cup... This is because the length of the mini valve is relatively short and that extra bit on the adjustement makes all the difference to the operation of the compressor...
#10 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 05 January 2014 - 07:45 PM
I have one of those and find it a pain with a series heads. I have to use a stack of big washers to pack it out and get it to work. I got one of these and it works much better:http://www.amazon.co...ring compressor
Metal not plastic. Works fine and has several adaptors so you can customise to make it perfect. I also got a couple for work as they are very good for the money.
#11 HarrysMini
HarrysMini
  • 3,352 posts
Posted 05 January 2014 - 07:57 PM
Think I'll go for that one then. Thanks for the advice :-)
