Hey all. I have just upgraded my indicator flasher from the original bi-metallic strip unit to a modern flasher unit and every worked fine. I put everything back together and noticed that my hazards and interior light stopped working. i found that the inline fuse had popped. I replaced and it popped again. I replaced the fuse with a slightly higher rating and the hazard flasher goes on and off (but not the actual indicators). I have disconnected the new flasher, disconnected the hazard switch, but its the same result. any clues on what has happened?
cheers
Rich
Edited by finch661, 04 January 2014 - 09:02 PM.
