Su Carburetor Configuration
7 replies to this topic
#1 newenglandmini
newenglandmini
  • 646 posts
Posted 05 January 2014 - 11:23 PM
What SU carburetor is correct for my '74 Mini 1000?  How do I confirm which carburetor is on my engine?  It looks bigger than the SU's on my MG-TD, so I assume that it's a 1 1/2" carb.
Attached File  DSCN4760.JPG   70.28K   42 downloads
#2 Ethel
  • 26,093 posts
Posted 06 January 2014 - 01:00 AM
That looks like a HS4 (1-1/2" choke) which is correct. Natty little  heater on it too, did it come via Canada?
HS2's have the mounting studs  at 12 & 6 o'clock; HS6 have four.
#3 Petro1head
Petro1head
  • 168 posts
  • Local Club: Cooper Register north est
Posted 06 January 2014 - 10:00 AM
Its a HS4 1 1/2 SU
#4 cal844
cal844
  • 9,651 posts
  • Local Club: TFMOC
Posted 06 January 2014 - 11:09 AM
Its a HS4 1 1/2 SU
+1
#5 newenglandmini
newenglandmini
  • 646 posts
Posted 06 January 2014 - 11:55 AM
Yes, it is a Canadian Mini.  I was told that Mini's were not sold in the US after 1969 because they did not comply with US bumper regulations.  I bought my car from a chap in Rochester, New York.  His father had purchased the car in nearby Ontario, and imported it.
Are you referring to an electric choke heater?
#6 newenglandmini
newenglandmini
  • 646 posts
Posted 06 January 2014 - 12:18 PM
Minispares offers a number of HS4 rebuild kits.
1. They make reference to a Waxstat carburetor (pre-'74).  My car is a '74...how can I confirm if it is Waxstat or not?
2. They also make reference to a plain vs. air valve throttle plate.  I presume that I simply need to inspect my carb to confirm that feature.
3. They also make reference to a "red jet".  It features a red band in the website image.  Do I need to inspect my carb for that feature as well?
#7 freshairmini
freshairmini
  • 1,718 posts
Posted 06 January 2014 - 12:33 PM
In regards to number 2 on your list. An air valve throttle plate (or butterfly as they are also referred to as) is a plate that has a little hole with a sprung valve on it that opens under certain conditions. The plain is obviously just a flat one, no valve. The general opinion is that the valved ones are not so great as they just cause an obstacle and restriction in the airflow of the carb due to the valve that sticks up off the plate and some people mod the plate to remove the valve and solder up the hole.
I am unsure about the waxstat differences so cant help you there.
#8 lrostoke
lrostoke
  • 6,923 posts
Posted 06 January 2014 - 01:36 PM
One on the right is waxstat, left is a fixed jet
right is one with air valve (poppet valve)
