Bad Fuel Pump?
8 replies to this topic
#1 purplesuit1
purplesuit1
  • 88 posts
  • Local Club: Beer Drinkers Anonymous
Posted 07 January 2014 - 05:52 PM
Hello
   The past couple days i have been experiencing a problem. When i am cruising on the highway the car is kind of sputtering, like stop and go really quickly with power going in and out (kind of hard to explain).
This only started a day or two ago and it has just recently starting doing it on regular non highway driving as well. I think it may be the fuel pump going out. What do you guys think?
#2 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 07 January 2014 - 06:01 PM
Need more info on your car
year?
engine size?
carb?
distributor?
Should like your fuel mixture or timing/points to me at the moment
#3 purplesuit1
purplesuit1
  • 88 posts
Posted 07 January 2014 - 07:01 PM
Sorry forgot to include.
1981 estate
998cc
HIF44
points dizzy
I know i should be using a HS4 but right now it is out of commission so i put the HIIF44 i had laying around on there. It was working for about 2 weeks until i had this problem. I checked the spark plugs and they look golden brown so i think the mixture is ok. If it was points, wouldn't it be doing this all the time? It only does it about 15 minutes into driving. Right now the needle in the HIF44 is for a 1275. I know the fueling isnt perfect but i dont think that is the problem, because as i said before it was working for roughly a couple of weeks before i started experiencing this.
#4 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 07 January 2014 - 08:07 PM
does it backfire through the carb? it may be running too rich or could be points or electrical related
#5 purplesuit1
purplesuit1
  • 88 posts
Posted 08 January 2014 - 04:23 AM
No backfire. Im not sure how to check the points, what should i be checking for?
#6 KingCraig
KingCraig
  • 75 posts
  • Local Club: Geeks 'n' Freaks Mini Club!
Posted 08 January 2014 - 08:42 AM
Sounds very similar to my current problem, so im commenting to get back to this easier and ill let you know if mine is solved.
(video on my post if you want to check what mine sounds like compared to yours)
#7 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 08 January 2014 - 09:07 AM
I would check your fueling and timing is correct, don't just assume its ok because your plugs look alright.
#8 purplesuit1
purplesuit1
  • 88 posts
Posted 21 January 2014 - 04:58 PM
KingCraig if you havent figured your problem out check your carb. I did a rebuild on mine and turns out the mesh filter inside my carb was very very clogged and i am pretty sure i have now fixed it.
#9 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 21 January 2014 - 06:37 PM
+1 on Purplesuit's comment.  Check and clean/replace any and all fuel filters inline between the tank and carburetor.  Also make sure the tank vent is not blocked and is open.
