Quick Release Rod Selector - @ Minispares
26 replies to this topic
#1 richw911
richw911
  • 2,084 posts
Posted 07 January 2014 - 06:02 PM
Just seen this on FB awesome!!
http://www.minispare...ssic/msg13.aspx :thumbsup:
#2 1984mini25
1984mini25
  • 8,784 posts
Posted 07 January 2014 - 06:19 PM
I personally can't see what the problem is with the roll pins, providing you use the correct size punch. Plus some thing wire looped round and twisted stops them from going anywhere if they do work lose.
#3 Sam
Sam
    Wish i was in T.O.W.I.E
  • 2,323 posts
Posted 07 January 2014 - 06:29 PM
I've never had a problem with roll pins either - but there are always loads of people moaning that they can't get them out. So for that reason, it's a great product and I'm sure they will sell well.
#4 markosparko1994
markosparko1994
  • 235 posts
Posted 07 January 2014 - 06:35 PM
I always have to mess around a bit with them, this is awesome, a bit pricey however
#5 eden7842
eden7842
  • 907 posts
Posted 07 January 2014 - 07:03 PM
I take my engine out quite often and think this is great however I do feel around £20 is more like it,
Tho the idea is the now so il make my own :-)
#6 Twisty
Twisty
  • 576 posts
Posted 07 January 2014 - 08:00 PM
good find mate i think this will be something i will be purchasing very soon.
#7 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 07 January 2014 - 08:09 PM
I can't really see how they can justify that kind of price. They must cost pennies to produce.
#8 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 07 January 2014 - 08:15 PM
I agree iy seems expensive, but when you price up doing it properly yourself (as I have done) it doesn't work out any cheaper. I have a stock of ally at work and plenty of time so that bit is free, but add in a couple of pip pins and you are up to that cost.
http://www.wdsltd.co...ll-ring-wds-955
You could do it cheaper with pins held in with r clips I suppose, but price up and small run alloy parts and they aren't cheap if you want them to tight tolerances and that would be useless if it flopped around. I think the £20 is very sensible and anywhere up to £30 isn't mad but I can see how they come to their price.
#9 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,229 posts
  • Name: Simon Jackson
Posted 07 January 2014 - 08:28 PM
If we had a gazillion made in China they'd be cheap. As with anything the initial batch is on a small scale production, to exact tolerances having and UK produced. If they were £10 each and lasted 5 minutes, they'd be an awful lot of upset people around. Not to mention the standard coupling is over £20 to start with
#10 dean
dean
  • 283 posts
  • Local Club: EDMC
Posted 07 January 2014 - 09:51 PM
something like that is well over due.
a mate of mine found a good way of making it quick release and removable with out having to remove the exhaust.
#11 leeuk
leeuk
  • 681 posts
Posted 12 January 2014 - 11:47 AM
Looks like I shall be buying one of these sooner rather than later as my roll pin has just decided to pop out on me again, Oh the joys lol !!!!
#12 Jase
Jase
  • 1,166 posts
Posted 12 January 2014 - 01:21 PM
Great product, placed my order with John Erra last week. Thanks for doing this.
#13 Cooperman
  • 23,289 posts
Posted 12 January 2014 - 08:23 PM
Never had a problem with roll pins. Jack the car up, put it in reverse and use the correct diameter pin punch.
If slightly loose after re-assembly either use a new pin or wire-lock the pin in place with standard steel locking wire.
#14 1984mini25
1984mini25
  • 8,784 posts
Posted 12 January 2014 - 08:33 PM
Must be an eco in hear....
 But unfortunately doing things properly for some is far too much hard work, hence the need to come up with solutions to things that were never a problem (or made out to be). like those 'quick release' engine mounts or the ones with the captive nuts....
#15 mk1leg
mk1leg
  • 9,343 posts
Posted 12 January 2014 - 09:21 PM
I have purchased 1 there on there way.......worth a try......... :proud:
