Speedo Drive Bolt
4 replies to this topic
#1 Gremlin
Gremlin
  • 2,142 posts
Posted 07 January 2014 - 11:04 PM
The bolt that holds the plate over the speedo output on the gearbox - does it normally have a washer?
#2 Ethel
  • 26,073 posts
Posted 08 January 2014 - 12:50 AM
A split washer is listed, but I can't see it being too critical as long as the screw doesn't bottom out in the hole.
#3 Gremlin
Gremlin
  • 2,142 posts
Posted 08 January 2014 - 06:50 AM
Thank you, it is fairly critical as Dad put the bolt and bracket ontop of the block the other day, I nearly cried as I just saw it fall down the pushrod hole, straight down the follower hole (tappet covers off) we tried everything, tipping the engine upside down, I've got a magnet and torch on a telescopic stick, shakin the engine whilst upside down.
Attached File  image.jpg   26.91K   6 downloads
Even when we split the block and gearbox, it still took ages to find it as we later realised it was caught in the selector mechanism!
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 08 January 2014 - 06:56 AM
The bolt you have in you hand is for the fork on the speedo cable adapter. It is a flanged bolt so does not require a washer but should have a dab of loctite on it.
#5 Gremlin
Gremlin
  • 2,142 posts
Posted 08 January 2014 - 07:03 AM
Yeah thats right, I wasn't sure if it would have a spring washer on it, the loctite will be in the sump somewhere
