Cut Oil Pressure Line
13 replies to this topic
#1 Minidude7
Minidude7
  • 79 posts
Posted 08 January 2014 - 03:13 PM
Hello everyone,
I have noticed a big oil leak in my mini and after some looking noticed that the plastic oil pressure line has melted on something and the split in two,
Does anyone know of a simple way to reconnect them that will work under pressures the car creates?? Or will I have to buy a new line?? Quick fixes would be most appreciated...
Rob
#2 Ethel
  • 26,074 posts
Posted 08 January 2014 - 03:59 PM
An oil gauge line? just a simple barbed hose connector should do, It may be a decent amount of pressure but the area it's applied to is tiny.
#3 Minidude7
Minidude7
  • 79 posts
Posted 08 January 2014 - 04:00 PM
Yeah it is... Thanks Ethal, just wondered if anyone knew the diameter I would need as I can't get to my mini at the moment to measure it...
#4 Ethel
  • 26,074 posts
Posted 08 January 2014 - 04:12 PM
I think the factory one is just 1/8" but it's rubber, not plastic and connects to a metal pipe above the clutch. yours sounds like an aftermarket gauge so have google, especially if you know the make.
#5 Minidude7
Minidude7
  • 79 posts
Posted 08 January 2014 - 04:14 PM
It a very thin nylon pipe that connects from the main block and on the the back of the oil pressure gauge on the back of the centre binnacle...
#6 Ethel
  • 26,074 posts
Posted 08 January 2014 - 04:44 PM
You may well buy some pipe cheaper/easier than a connector
#7 Craig89
Craig89
  • 600 posts
Posted 08 January 2014 - 04:46 PM
If it's the one from minispares then its like a nylon air hose, unsure of diameter but something like this is what you want:
http://www.amazon.co...edir_mdp_mobile
#8 Scott@minispeed
Scott@minispeed
  • 200 posts
Posted 08 January 2014 - 04:56 PM
If you are after a quick get you back on the road in the fastest way type fix then remove the T-Piece from the block, remove the oil warning light switch from the T-Piece and put it directly into the block. Your car will stop leaking oil and your oil light will work but your gauge will not until you replace the pipe.
Don't bother trying to repair the nylon pipe they are very cheap and the risks of a botched repair going wrong are pretty high. Just buy a new pipe and fit it all back when you get a chance.
#9 Minidude7
Minidude7
  • 79 posts
Posted 08 January 2014 - 05:28 PM
Thanks everyone, I intend to buy a new one long term but needed a quick fix to last me a few days until it arrives... Would heat shrink tubing around the two ends to hold them together not work for now??
#10 Craig89
Craig89
  • 600 posts
Posted 08 January 2014 - 05:33 PM
No. As a quick fix do as above, remove and put the oil pressure switch into the block
#11 grumpy dad
grumpy dad
  • 305 posts
Posted 08 January 2014 - 08:35 PM
Hi
both these are Bad  tips but will work
fold the end of the pipe and use mole grips to hold flat
on the motor side
if the mole grips fall of you will lose all your oil
and trash the motor
undo the pipe at the motor and find a small
ball bearing that is a bit bigger than the inside diameter
of the pipe and screw the pipe back on
check for leak
keep fingers crossed
#12 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 09 January 2014 - 12:00 AM
Without causing any more issues, I'd just do what Minispeed said... It's fast, guaranteed to work and is safest as you won't be losing any oil AND you still have the opportunity to know whether you have low oil pressure (by screwing the switch in instead of switch and t-piece)
#13 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 11 January 2014 - 02:45 PM
This is one more vote for screwing the pressure warning switch directly into the block until you buy a new oil line kit.
If you don't have a switch and are only running the pressure gauge go to the home center and buy a 1/8" pipe plug.  Remove your oil line adapter from the block and replace it with the plug.
Long term, buy a new oil line kit.  The nylon kits have problems as you have just experienced.  There are also nice OEM kits, braided steel hose kits, and copper tubing kits.  The copper line kit is a compromise that is more reliable than nylon for only a little more money.  When using copper, remember that you must loop the excess copper tubing into "spring coils" between the engine block and firewall.  The loops in the copper tubing absorb engine vibration and motion so the tube does not fatigue too quickly.
#14 Minidude7
Minidude7
  • 79 posts
Posted 11 January 2014 - 04:08 PM
I completed as MiniSpeed stated and ordered a new line for replacement!! Cheers everyone for the help
