Putting Mini On Axle Stands
7 replies to this topic
#1 JamesleppAFC
JamesleppAFC
  • 49 posts
Posted 10 January 2014 - 09:13 AM
Can anyone tell me the best location to put the front of my mini sprite onto axle stands.
#2 MiniMadJamie147
MiniMadJamie147
  • 17 posts
  • Local Club: Potts About Minis
Posted 10 January 2014 - 09:18 AM
Jack up where the front of the tie bars go... Axle stands on subframe. Do not use Floor pans!
#3 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 10 January 2014 - 09:47 AM
As above, there was a guide somewhere showing you how to jack up and axle stand a Mini. But generally, just stick to the subframes and it'll be fine.
#4 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,044 posts
Posted 10 January 2014 - 10:05 AM
On the flats of the subframe, have a look at this thread
http://www.theminifo...-other-matters/
#5 lrostoke
lrostoke
  • 6,923 posts
Posted 10 January 2014 - 10:06 AM
Unless its the subframes that need to come off, then use some strong planking across the floor pan and put the stands under that.
Scaffold planks are ideal
#6 Em_the_Ghostie
Em_the_Ghostie
  • 186 posts
Posted 10 January 2014 - 12:24 PM
+1 for the subframe :)  Jacking points should only be used with the original jack - to be honest I wouldn't use them even then!  Renound for failing.  Don't fancy a big hole in the floor!!
#7 Cooperman
  • 23,368 posts
Posted 10 January 2014 - 12:31 PM
I have 4 plastic bottle crates which I use under the floors when I need to remove a sub-frame. In the case of the front sub-frame I remove the engine/gearbox first with stands under the sub-frame adjacent to where the lower arm fits. Then when the engine is out I place the plastic crates under the front floor.
The only time this doesn't work is when the steering rack or sub-frame mounts have to be changed as the sub-frame with engine on it needs to be dropped. In that case I use two large squarepieces of wood on top of the crates to spread the load better
#8 JamesleppAFC
JamesleppAFC
  • 49 posts
Posted 10 January 2014 - 09:01 PM
Thanks for all the info:)
