Issue With Main Caps
Best Answer ACDodd , 12 January 2014 - 03:36 PM
Yes, remove the crank and torque the caps with the bearing shells fitted and investigate. If you can put a feeler blade under the main cap when torqued your build stops right here till you get it investigated.
Ac
Go to the full post
Posted 12 January 2014 - 02:29 PM
Everything is beautifully clean but something isn't right. Any suggestions?
Posted 12 January 2014 - 02:38 PM
Guessing you have tapped it into place with a rubber mallet? should locate
Posted 12 January 2014 - 02:42 PM
Posted 12 January 2014 - 03:36 PM Best Answer
Ac
Edited by ACDodd, 12 January 2014 - 03:36 PM.
Posted 12 January 2014 - 03:39 PM
Any suggestions as to what could be causing it AC? Is it worth removing the dowels to see if everything bolts up correctly as a process of elimination?
Posted 12 January 2014 - 03:42 PM
Ac
Posted 12 January 2014 - 03:47 PM
I will try that tomorrow evening then and let you know how it goes. If I go into the garage right now I am worried I will accidentally on purpose set it on fire. ![]()
Thank you AC.
Posted 14 January 2014 - 06:08 PM
Took it all apart, cleaned it all scrupulously, removed the dowels, then cleaned where they sit, put it all back together again and it works beautifully.
I am a happy boy.
Edited by MrBounce, 14 January 2014 - 06:08 PM.
Posted 14 January 2014 - 06:51 PM
its also worth checking that the dowels are a decent fit in the block and caps,
If they are a bit loose, I recomend the ones swiftune do, they are thicker and better tolernced, and are only about 15 quid the set.
Posted 14 January 2014 - 07:08 PM
