Spot Lamps!
Best Answer alex-95 , 12 January 2014 - 06:03 PM
I've just got a set of them, You'll need wiring and mounting brackets. they do a kit for wireing them but I'm planning on making one with the help of dad.
You can get them a bit cheaper here http://www.ebay.co.u...=item3a88f1d5fc
heres the wiring kit http://www.ebay.co.u...=item5d430568d0
Go to the full post
6 replies to this topic
#1 Ashley1996
Ashley1996
  • 31 posts
Posted 12 January 2014 - 04:33 PM
I am planning on buying 4 spot tamps for the front of my mini, but not sure what ill need :/ these are the ones i want to get http://www.minisport...e-lamp-set.html
but will i need anything else? fixings, wiring? and is it possible to make them low beam + high beam?
#2 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 12 January 2014 - 05:53 PM
http://www.theminifo.../?hl=spotlights
#3 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,035 posts
Posted 12 January 2014 - 06:03 PM   Best Answer
#4 Ashley1996
Ashley1996
  • 31 posts
Posted 12 January 2014 - 09:05 PM
Thanks a great help thanks!
#5 Ashley1996
Ashley1996
  • 31 posts
Posted 14 January 2014 - 09:41 AM
I brought a two pairs and they just arrive today, it says it came with the brackets but I can't tell how to attach?
#6 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 14 January 2014 - 11:51 AM
Can't you remove the brackets that are currently on the spotlights, and replace with mini MPI spotlight brackets. If you only have two, the holes are pre-drilled on the body.
#7 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 14 January 2014 - 11:52 AM
Two pairs. >_<
:tumble:
