1994 Mini 35 Alternator Light
5 replies to this topic
#1 lindley94
lindley94
  • 48 posts
Posted 14 January 2014 - 05:20 PM
I have a 1994 1.3 rover mini 35, and my alternator light is constantly on, and the previous owner had recently replaced the battery.
Would I need a new alternator or are there some things I should try to rectify it first? Thanks
#2 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 14 January 2014 - 05:30 PM
does it charge the battery?
#3 greenwheels
greenwheels
  • 689 posts
  • Local Club: Mini Fixers
Posted 14 January 2014 - 05:41 PM
You could be driving just on the battery that will go flat on you eventually
A voltmeter across the battery with the engine running should give about 14 volts.
#4 lindley94
lindley94
  • 48 posts
Posted 14 January 2014 - 05:47 PM
Ok thanks I will give it a test in daylight, not sure if its charging yet, havent driven it much, got it home 2 days ago, so could be running on battery charge
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 14 January 2014 - 11:26 PM
The voltage your looking for at 2000rpm is between 13.7-14.3v which if your not getting and the light is on all the time points towards the alternator is not charging. Voltmeter on the battery do the tests and then either take it to somewhere who does repairs or a exchange unit.
#6 tiger99
tiger99
  • 8,584 posts
Posted 16 January 2014 - 11:50 AM
A quick and not so accurate test is just to switch headlights on, then start and rev the engine. Do the lights get brighter? If so, it is charging, to some extent.
However, 99% of the time it usually means a new alternator, as there are very few other common faults that make the warning light come on. but check that the connecting plug is clean, with no sign of anything that could be shorting the thin wire to earth.
