1380 build glitch
deanymini
, May 29 2006 09:30 PM
11 replies to this topic
Posted 29 May 2006 - 09:30 PM
i got my 1380 installed last thursday and everything seemed fine in the first 2 days. was trying to run the engine in and did about 50 miles or so, however, on saturday night the car became undrivable.
when i start accelerating in first gear everthing goes fine until about 30 seconds of driving when i hit about 3000 revs in third gear, then all of a sudden the engine just dies and doesn't accelerate any more. i have to keep dropping gears until i come to a stop. if i leave the car at idle for another minute or so the engine seems to recooperate and i can drive it for another 30 seconds or so until it dies on me again. has anyone got any idea what it could be?
Posted 29 May 2006 - 09:34 PM
could be millions of things, hows ur fuel pump?
Posted 29 May 2006 - 09:45 PM
it seemed to work fine before the rebuild. are the standard fuel pumps ever too weak for a 1380?
Posted 29 May 2006 - 09:49 PM
hummm sounds like underfueling
Posted 29 May 2006 - 09:50 PM
Are you using a mech fuel pump? if you are i would suggest you use an electric one. I am no expert but i have had trouble with using a mech fuel pump on my 1330.
Posted 29 May 2006 - 10:49 PM
Deffo sounds like fuel starvation, pump fills float bowl with fuel at idle, engine consumes fuel faster than the pump can supply when under load, float bowl empties and engine starts to hesitate.
Id check the pump is working correctly first, is there fuel in the oil??
Probibly easier to change the pump for a new one ( Not Used) and see if its any different
Depending on tune of the 1380 the mech pump may well be inadequate, an electric pump will be required.
Posted 29 May 2006 - 11:22 PM
its a MSPD 1380. MSPD stage 3 head. SW5 cam. HIF44 carb. stage 2 maniflow, etc, etc. would it be worth me buying a facet red fuel pump? how hard are they to fit?
Posted 29 May 2006 - 11:37 PM
you need an electric pump
Posted 30 May 2006 - 05:11 PM
what was it going like out of intrest as i have nearly finished mine and am despirate to put it in and drive it and have never driven a fast na mini my mates turbo it fun but just wondering what its like so far??
Posted 30 May 2006 - 05:31 PM
A mechanical pump will be fine on that spec engine, jus tget a new or good used one and replace yours. I ran a mech pump with no probs on my 1380 and it was a higherr spec than that.
Posted 30 May 2006 - 06:18 PM
supermotolee i cant really comment because i was running the engine in so couldnt tell how powerful it was, also bearing in mind that the car hasn't been tuned on a RR.
i've booked the car in at the garage around the corner, i hope they dont do me over and charge me a crazy price.
Posted 31 May 2006 - 01:10 PM
It's fuel.
I use mechanical fuel pumps with no reported probs yet.
